Shocker First Maiden Run -- ESC Literally BLOWS through Hull
  • dmitry100
    • Mar 2015
    • 1264
    #61
    Um oops ... I kind of misread the link thinking it was CF cloth with adhesive... but would be interesting if someone had something like that though...
    • dmitry100
      • Mar 2015
      • 1264
      #62
      I think ideally it'd be something along the lines of >> https://www.acpsales.com/OnlineStore.php?cat=5467
      I wonder if I would technically need to add any additional epoxy or anything to this...
      • T.S.Davis
        • 6220
        #63
        Originally posted by kfxguy
        I'm running a 1515 2200kv castle motor on 6s in my 26" cat. Runs like this with no issues, day in, day out.
        You run this every day. That's great. This was your first build of course? 6s in a 26" boat. Good plan. I'm sure she turns on a dime.
        This is the kind of info that I'm talking about. A guy reading this thread that is looking to get into boats is going to think...............some guy said I could run 2200kv on 6s easy.......and go real fast too.......... I'll just do what he did........ accept he doesn't know how that boat was built. He doesn't know how to even build a boat. He doesn't know anything yet.
        It's exactly what led to the failure that inspired this thread.
        The expensive equipment we've been through is due to mistakes we've made and learned from. It was an attempt to qualify our opinions. You know, let others benefit from the mistakes we've made. Blasphemy I know.
        When looking for setup advice, each has to decide what parameters define an "expert". Do you take advice from accomplished racers with multiple national championships/records or do you take it from guys with some Youtube videos? A call each will have to make for themselves.
        Noisy person
        • dmitry100
          • Mar 2015
          • 1264
          #64
          Just for the record... 6s was what this guy recommended. Tiny motors, 180 amps and 38mm props... Didn't even think twice about starting off with lower voltage. I think driveline could have been one of the issues-- as it was not spinning as freely as the other side was. Usually when you spin you could feel the magnets chiming... this side was not. Seemed like the flex was at a bit of an angle (not lining up as perfectly into the collet). It seemed to line up fine after I loosened up the motor mounts and would spin just as flawlessly as the other side would.
          • Spartanator
            • 1060
            #65
            I guess it depends where you get your V3 from. I got mine from Falcon Sekido (something like that) and a few that have gotten theirs off EBay and HK have blown up. I would bet some QC testing plays a factor with the ESC smoke.
            Anyways, good luck on the rebuild!
              Turning on a dime has something to do with kv choice? That's a new one by me. Please elaborate...
              If someone sees my post and decides to just throw the same motor in a boat on 6s and let it eat without knowing what they are doing, that's on them. The first boat I built was a 32" Rivercat. It had a 1515 2200kv. Yes, I smoked the Esc in about 30 seconds. I had like a 45mm 3 blade prop on it. I learned on my own the hard way. I've come quite a long ways in 2 years, you know it, I know and pretty much everyone on here knows it. Can I set up a reliable 40k+ rpm boat? Absolutely. I've done I quite a few times. Will parts fail? Absolutely. I've seen parts fail for no reason and I've seen stuff that lasted and shouldn't have. We can agree to disagree. No problem. We are still boating brothers. We just do things differently. That's what makes it interesting.
              Back to topic. I really don't think he was pulling over 150 amps with this setup. I think he simply had a defective controller. I had a seaking 120 do the same thing to me a few weeks ago on a mild setup. Put a new one in no changes and it's fine.
              • Luck as a Constant
                Make Total Destroy
                • Mar 2014
                • 1952
                #67
                The question is...
                How long is he running it?
                1-2 passes or 3-4 minutes out there at wot.
                Two different things
                • dmitry100
                  • Mar 2015
                  • 1264
                  #68
                  2-3 minutes ... a few 10 feet passes at barely half throttle near the dock. I didn't punch it or anything as the throttle was pretty sensitive.
                  • T.S.Davis
                    • 6220
                    #69
                    Sorry, kv has nothing to do with turning on a dime. Although, high RPM will make the rear end swap out on you pretty hard. 6s in a 26" boat wont turn. Not well at least. Just like it didn't 12 years ago when I put 16 Nimh cells in a 22" cat. Straight was fast but no turns allowed. It's a weight to footprint thing.
                    But.......hey.....I could be wrong. Bring that up to MI. We'll race that 26" 6s boat in Q cat. Should be stellar against PAGS sprint cat. He's only running upper 60's. Although, turning on a dime is kind of his thing.
                    You've come a long way and we all know it? Wow, don't pull a muscle patting yourself on the back. Sorry for not acknowledging your many accomplishments. I'll have to revisit the NAMBA and IMPBA records.
                    hahaha We've been reduced to the age old debate. The sporties telling the racers "you don't know what's what" and the racers saying "yeah, come show me".
                    Still toys.
                    If this burns up another speedo, who's paying for it?
                    Noisy person
                    • iop65
                      • Mar 2013
                      • 367
                      #70
                      reading more and more from Dmitry i can guess he hasn't got the knowledge or experience for this set up ,it's like an 18 year old buying a Ducati 1299 s and ending up glued to a tree
                      sorry Dmirti but if you can't run it full throttle : change something !
                        • 7673
                        #71
                        So it was running at the time of mishap with the binding on one side? That could create some heat for sure. But I read you may not be 100% confident in the water flow. This would drastically increase temps quickly and help cap failure.
                        • dmitry100
                          • Mar 2015
                          • 1264
                          #72
                          iop65: lol gee thanks buddy except if you maybe guessed that I didn't build it-- if I had I would have taken extra precautions. Perhaps you can enlighten me on what you could have done any differently in this situation mr. ducati 1299
                          At the end of the day I have enough "knowledge" to figure out what the builder did wrong and to fix it... as I believe it was the driveline that contributed to this if you can read above. Flex wasn't aligning properly to the motor coillet. But I'm not sure how any of this would even compare to a ducati 1299 though. When I bought my M5 and 750 BMW's they didn't blow up on me after putting the recommended 91 octane gas into them and passing 15 mph... neither did I hit any trees. I usually have an expectation of a certain standard of quality when you pay a little extra for someone or a company to put it together for you where as it should never go BOOM after the first 2 minutes of use. But these components are Made in China after all. That's why I'd rather buy German from now on... they seem to have good stuff even when it comes to these boats it seems.
                          I just want a boat I could use everyday in between work breaks that is reliable and goes fast... so far I'm finding it to be quite an adrenaline rush and I don't have to be inside of a boat or a race car for it. I like the idea of having to build and program something myself and being able to run it-- it becomes a whole other level of fun.
                          • dmitry100
                            • Mar 2015
                            • 1264
                            #73
                            srislash: Yep. Sounds like a combination of things gone bad... and ka-boom :) The builder was just in a hurry I could tell. Was even missing a bolt on the rudder.
                            • Ken Haines
                              Racer
                              • Jul 2007
                              • 647
                              #74
                              Hello Dmitry,
                              There has been a lot tension and stones thrown in this thread. I respect your questions here and think most of us do.
                              The last thing we need is to chase off a fairly new FE boater, or make him hesitate to ask questions.
                              The reason Terry and I posted our 6s on 1900kv comments was to help warn you that this is a risky set-up.
                              We understand that it was purchased that way so in no way is that a slight toward you personally. Those that have
                              taken cheap shots at you because of your questions....shame on them. I just like Terry once upon a time when I was a
                              relative beginner tried a 6s setup on a 2200kv motor. It was top of the line Neu 1527-1D in a 36" mono. This one on
                              a Schulze 40.160 (the good old version) German as they get Btw. These ESC's are recognized as the best of their time
                              and still considered the best by most top racers. The boat ran terrific for a minute or two. Fortunately I was running in
                              close quarters very near the shore. I probably never went over 30 mph in about a 100' area, but had some quick bursts.
                              Then the boat stopped, before I could get off the hatch tape off the $650 Schulze was on fire and was totally destroyed.
                              For a week or so I really wondered if this was a hobby that I could afford, but then I too reached out to guys like Terry Davis
                              and many other well known racers who had much more experience at the time. They were more than happy to share their
                              experience and advice. Hopefully you can weed through the differing opinions and at least try some of the conservative
                              thoughts / setups spoken about here first so that you will continue in this great hobby for a lifetime.
                              You may want to even try a PM or 2 to stay out of the firing line on some things.
                              Good luck with the Cat....from what you have written here so far it sounds like you will get this all worked out in the end.
                              Ken
                              Alias Fireball...
                              TenShock Brushless / Pro Marine
                              INSANE Boats / Rico Racing/ Castle Creations
                              2023, 2024 NAMBA & 2018 IMPBA FE High Points "National Champion"
                              • tlandauer
                                • 5666
                                #75
                                May I just echo that I have also learned so much from these people who have been racing for a long time and had their share of set backs. There is always a learning curve and for each of us it may be different, but nonetheless it takes time and experience to get to a specific goal that is again an individual calling. Anyway, my personal take on this hobby is that speed is not everything, (I know some people will snicker, but who cares?) for me it is the pleasure I get knowing that every component is working in harmony and I still have a margin to push if I so choose.
                                I wish you good luck on repairing the hull and get your set up working to your goal.
                                Sent from my D6708 using Tapatalk
