push button hatch locks - sealing
  • hsp-sandiego
    • Dec 2012
    • 32
    Installing some push button hatch locks in my Pursuit and noticed that there is no seal, so if boat flips, water will seep though slowly. Do you who use these use some grease in them or any other "tricks?" thank you.
    • 7673
    Nothing I ever worried about. Unless air can easily escape through the bottom(ie: stuffing tube, rudder pushrod boot). When it is upside down it should be an airlock.
      Last hatch locks I used, I figured a way to put o rings in them. Just in case.
      • ray schrauwen
        • 9472
        I use little balloons sold at Lee Valley used for covering caulking gun tips. There are also rubber caps on ebay yo can buy if it has an inner diameter a little smaller than the remainder threads below.
        • capnswanny
          • Feb 2012
          • 817
          ....and the winner of the 'not-so-elegent solution award' goes to....me!
          4 precisely placed pieces of hockey tape :)
          This is NOT a toy?!?
          • tlandauer
            • 5666
            Long live the tape men.
            I enjoy the ritual actually, may sound sick to some, but it's the truth.
            Sent from my D6708 using Tapatalk
              • 7673
              I enjoy the ritual actually, may sound sick to some, buy it's the truth.
              Just don't flip...
              • tlandauer
                • 5666
                Originally posted by srislash
                Just don't flip...
                • ray schrauwen
                  • 9472
                  On my 40" mono I used a pair of front tabs made of aluminum and rear hatch locks as well as 4 pieces of tape. If the batteries ever came loose (6S2P) tape would have not helped much. Some things need more than tape but, most don't.
                  • capnswanny
                    • Feb 2012
                    • 817
                    Hehehe, I was actually suggesting placing a piece of tape over each hatch lock to "waterproof" them
                    But while you got the tape out, might as well finish the job!
                    • hsp-sandiego
                      • Dec 2012
                      • 32
                      It happens when you are running with others.
                      • hsp-sandiego
                        • Dec 2012
                        • 32
                        It happens when you are running with other boats in the water.
                        • hsp-sandiego
                          • Dec 2012
                          • 32
                          This is what I though after I posted... why not caps threading on the bottom. Rubber or silicone; easy enough. thank you. *Just ran 3 sets of packs and headed back after charging at home, today being "power" day at our model boat pond. I like having the hatch locks. I have seen and heard, "but I had it taped" a few times... not enough to keep the hatch on sometimes, especially when it's cold out and the tape isn't tacking up well.
                          http://www.ebay.com/itm/171338540608...%3AMEBIDX%3AIT
                          • tlandauer
                            • 5666
                            I was half kidding: to successfully rely on tape, one MUST install hatch retaining pins or tabs under the front lid.
                            I do use hatch locks but I have a sub hatch which I still TAPE!
                            • hsp-sandiego
                              • Dec 2012
                              • 32
                              In case anyone needs info on these, sealing with a cap is a great idea, although air-lock is there is the tape is COMPLETELY sealed. In any case, tape is NOT ENOUGH! use hatch-locks or eventually lose your lid and $$.
