push button hatch locks - sealing
  • razzle
    • Feb 2012
    • 46
    P1050869.jpgP1050867.jpgI don't use tape I use thumbscrews with a neoprene seal you will never lose your hatch and its a watertight seal!
    • pistol18
      • Sep 2012
      • 248
      Dazzle, what hull is that? She's a real beauty!
      Tape only on my smaller rtr boats and hatch locks plus tape on the bigger hulls
      • razzle
        • Feb 2012
        • 46
        Pistol18 it's a Swifter hydro from R2 hobbies just painted it myself and added decals then clear over the top!
        • sundog
          Platinum Card Member
          • Feb 2009
          • 878
          I've tried cutting them shorter, but can't seem to cut them flat/level? enough, so now leave them long.
          Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
          • Tamelesstgr
            • Jun 2014
            • 1516
            I have been looking for some options about hatch screws and came accross you red boat with the thumb screws. Can you let me know where I can get some like that please? Also, what about the neoprene seal?
            Thanks,
            Ken
            NEVER SATISFIED RACING
            Fine Design 32 V-Hull 4082+6s
            • phil t
              • Feb 2010
              • 169
              how about rc car Proline screw down body mounts you can use oring with them.
              The Grim racer push button lock have a oring too.
              Tower Hobbies carries an expansive collection of RC cars, RC airplanes, RC boats, model trains, sot cars, and supplies for all hobbyists.
              Phil Thomas
              email [email protected]
              http://www.philthomashydros.com
              • Luck as a Constant
                Make Total Destroy
                • Mar 2014
                • 1952
                Thanks,
                Ken
                Kbb has the seal.
                I got my thumb screws at Home Depot, but some guys get em online.
                • Turbo Dan-O
                  • Feb 2011
                  • 292
                  #23
                  Yes, I would like to know this as well.
                  Pursuit: T-180, TP 4060/1620kv. Genesis: T-180, GoolRC 2000kv. UL-1: Bone stock. MHZ Tsunami: Full tilt SAW project!
                  • kevinpratt823
                    • Aug 2012
                    • 1361
                    #24
                    I put a silicone O-ring (shock seals for my rc cars) on under the spring. It does the trick very well. You just need the right size that will fit down into the recess nice and snug. Some hatch locks you can remove the lower cross pin if it has a set screw (requires some heat, as that loctite is solid), others you can stretch the o-ring over the top button, then work it down to the bottom of the spring. Along with some foam rubber weatherstripping tape around the hatch, I've had boats upside down for 10 minutes and only get a shot glass of water at most.
                    My private off road rc track
                    https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8
                    • 785boats
                      Wet Track Racing
                      • Nov 2008
                      • 3169
                      #25
                      These have the O ring too.
                      • Pau7060
                        • Nov 2014
                        • 67
                        #26
                        Would the squeeze end of eye dropper work to seal up the bottom side of the hatch lock.
                        • gearhd48
                          • May 2015
                          • 139
                          #27
                          Hey Razzle...I'm putting one together now, I was wondering if I could bother you for some assembly and set up tips??
                          SW26 V3 Green 35mph , Swifter Hydro 26. Delta Force 35. cars ,3 Rustlers 45-76 Mph.
