HELP with setup for Atomik arc 58 cat
I played with timing and the most I gained was .3mph....but that was my setup. In your case I still don't think you'll gain enough to surpass 60. But I will put money on it that if you switch to revolectrix batteries you will pick up about 4mph...... I remember you had maxx amps right? In my testing, they were the weakest battery I tested. Also the most expensive. The cheapest battery I tested smoked all the others. The only one that came close to revolectrix was spc. Like I said....I'll put money on it you'll go faster.....32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I dont trust cheap Chinese batteries. Especially ones that only come with a 60 day warrantyIm a firm believer in you get what you pay for. Maxamps come with a lifetime warranty,they are 100% waterproof,And they can make custom batteries upon request. Plus i like to support my local.They are made right here in Washington state
Good thing I was able to get that update and access my parameters the LVC was set at 2.5v per cell.That could have been bad. I set it 3.2v per cell but my run time was like cut in half .Why is that? And when I turn my boat on it beeps twice followed by 10 beeps? Shouldn't it only beep 8 times for 8s?
cheap cells cannot take a big amp load without a big dump in voltage like you are seeing
the lifetime warranty is limited and hard to claim after so many months
and most all lipos are waterproof, meaning they can get wet.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
Y winds do like more timing vs D winds
if you have a D wind, you will most likely see more heat with no performance improvements.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8sComment
Those are odd looking connectors on your batts, wires look pretty thin too, what gauge are they?NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Ok. You win. When you burn another esc up, (how many have you burnt so far?) Then maybe you'll listen and get good batteries. Notice I said good, because max amps are not good. I did back to back testing that proved it. They are the highest rated battery I tested, but by far the slowest and weakest. If you find the huge lipo test a guy did on the web, it will prove the same thing to you. It does not matter that your batteries are fine, you keep having esc failures because you choose to keep running batteries that can't keep up. I'm sorry you paid so much for them, but you need to suck it up, cut your losses and get good batteries and you'll quit burning esc's. Seems like you have it in your mind that the batteries arent the culprit.....so I wish you luck.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
