Custom sliding strut assy....
    Got the the mill table dro's installed. This is going to make things much easier, faster and more accurate to make! Dj, you still need a cooling block?
    • olwarbirds
      Magic Smoke Wizard
      • Oct 2012
      • 1136
      Travis, yes I do brother...need one for the T180 V2.... DJ
        Ok. I had to work today, (had a pretty bad day too )then when I got home, took the wife out to dinner. Then when we got back I wanted to test the dro's I installed. Man! I should have put this on a long time ago! Made thing so much easier and better! Anyway...believe it or not, I'm almost done with the strut. Got a boy 4 hours work into it...but is worth it. It looks good. I forgot to take some pics of the base, I'll do that tomorrow. Here's what I have for now.....
        Starting the male dovetail...
          Now starting to thin the strut mount...
          Rough cut out of the strut mount...
            Plunge cut for the screw....
              There will be a collar or nut that locks the screw in place from moving up....so I cut a recess for it.
              That's all the pic I took for now. The slide mount that goes on the transom is almost done. I decided to put a .035 stainless shim it it to make it tight and to keep wear to a minimum. Epoxy is curing. I have to run to my uncles house tomorrow to cut the slot. I'm too far to mess up now. His mill is much better than mine and i don't want to mess it up! Stay tuned...it's almost done!
                Getting there.....Here's the assembled piece....
                • tlandauer
                  • 5666
                  Looks fab!
                  • flraptor07
                    • Aug 2013
                    • 2451
                    Dude, That's badass, you deffinetly need to set up to duplicate those. I'd take a 1/2 dozen myself!!
                      More pics
                        Just cut the slot. If you ever cut a skinny slot like this and this deep......you know it's a pain in the ass!
                          • 7673
                          #27
                          Looks great Travis. And:
                          Ditto
                            I just emailed Dave at hrc. I can't make these for you guys as much as I'd want to. It takes way too long to make one in a manual mill. So....I asked Dave if he would be interested in making copies...once I test it and make sure it works properly. I'm pretty sure it will. On a positive note, it move the prop back another 1/2" so that will ever so slightly help with blow overs be a use I know that's coming soon. If your interested in one, speak up. I'm going to forward this thread to Dave if he is interested.
                            • flraptor07
                              • Aug 2013
                              • 2451
                              #29
                              That works for me, Dave's shop is only about 5 or 6 miles from my house!
                                Wonder if it would be better for me to send it to you and you bring it to him?
