80+ mph 32" rivercat
  • iridebikes247
    • Dec 2011
    • 1499
    Better batteries helped a lot I noticed a substantial gain in rpm switching from zippy 40c batteries to dinogy 65c.
    Etti makes a very solid 150a/300 esc capable of 7s if you're worried about it. 80 is a good goal but I think you'll get more eventually. Have you ever considered cutting down larger props? This is what I usually do in twin cats im sure this isn't too different. You can definitely run 7s to that motor I think that + some more prop tuning will get you to your goal and then some, just keep an eye on temps!
      • 8749
      Good to know. I was thinking about switching to 65c spc batts. i could cut down props, I may give that a try also. At this point, I have so much more I can do I know i can surpass my goal.
        • 8749
        Tried the sea king 180 on 7s and it won't arm. O well. Now I need another esc. I'm thinking mamba xl2, epoxy coated, remove circuit board from case and make a custom high capacity cooling block then heat shrink it.
        • Spartanator
          • 1060
          Should try to find a used ESC on EBay or something... I past up a great deal on accident one day...
          Oh, Sorry about the eCheck thing earlier.... Still mad at myself for that one. lol, someone here said they use the SK180 on 7s but hadn't smoked...
            • 8749
            Well my seaking 180 won't even power up on 7s. It beeps once and that's it. Unplug the 4s pack and plug in a 3s and it works fine.
            • iridebikes247
              • Dec 2011
              • 1499
              i got 12 mph going from a 447 to a 457 red to 50. gives an idea of what cut down props can do. higher rpm and pitch will be the answer as you know.
              • keithbradley
                • 3663
                Keep in mind that while cutting props down might work well in a twin, that doesn't necessarily mean that it will in a single. Twins can run smaller diameter because they have twice the thrust. Small diameter props on a single drive boat can lead to drivability issues and excessive slip.
                www.keithbradleyboats.com
                  • 8749
                  #23
                  I have a Prather 225 and 230 on the way. I just need a higher voltage capable esc
                  • iridebikes247
                    • Dec 2011
                    • 1499
                    #24
                    yup, i was thinking the twin vs single prop choice might be a bit different for SAW setups.
                    when i say cut down i mean cut down a bigger 4-series octura to a similar diameter prop that hes running. When you have the headroom its fun to play with setups, given Jay gave exact information for his SAW setup with the same boat I think the prather with the same rpm might be your ticket, he has the experience with the SAW singles.
                    • iridebikes247
                      • Dec 2011
                      • 1499
                      #25
                      As far as escs go my friend ran the etti 150 with a 1527 neu a few years ago, a very hard setup and he had a good experience with it.
                        • 8749
                        #26
                        I looked at that esc but I wasn't sure if it would hold up. The mamba xl2 is out. Not going to fit. The only way it will fit is if I machine a custom low profile billet case. I'm not doing all that work to use an iffy esc. I think the Prather props will pick me up a tad especially since I can thin them a little more than the Octura props.
                        I think ose is out of the etti...any other place to get one?
                        • flraptor07
                          • Aug 2013
                          • 2451
                          #27
                          Did you get the Bronze or the Stainless Prathers?
                            • 8749
                            #28
                            Stainless
                              • 8749
                              #29
                              Found an etti 150 esc. Hopefully get it by next weekend. Now on to splitting hairs while I wait on other stuff. Here's my plans so far:
                              -Ceramic motor bearings
                              -Ceramic roller strut bearings (I already have the strut roller as it is. I have 6 sealed bearings in it and it seems to be holding up fine. I've never run this boat without the roller bearings so they do have a little use on them. I have regular steel bearings in it just as an experiment.
                              -higher mah and c rating batteries (I have 5000mah 50c, going to 6500mah 65c)
                              -better prop, checking on having a Custom one done.
                              -new esc
                              -7s up from 6s
                              Those few things should pick me up
                              (Hair splitting lol)
                              • MarkF
                                dinogylipos.com
                                • Mar 2008
                                • 979
                                #30
                                kfxguy
                                If you want to go fast try the abc line of props. Maybe a 1816 for starters.
                                Mark
