Travis, a bit off topic here but have you had any probs with loosing sat signal on your garmin 201...I did a serious series of somersaults, tumbles, rolls at very high speed with my Genesis yesterday and my gps unit came out DOA...so now I need another gps...good deal on a garmin 201 on ebay....DJ
80+ mph 32" rivercat
Tunnels-PS295. Cats-H&M M1 Supercat Daytona rivercat. Monos-DF Cyberstorm HiTech 29. Hydros- Ms K Vac-U-Pickle Custom built 37" shovel 10th scale converted to FE Shadow. Rigger-H&M Evo II. AQ Harbortug recovery boat. Build in progress 37" cf Dragboat -
I've had three of them. Every one worked flawless. I had one of them over 5 years. Two of them are at the bottom of lakes is why I don't have them anymore lmao!Travis, a bit off topic here but have you had any probs with loosing sat signal on your garmin 201...I did a serious series of somersaults, tumbles, rolls at very high speed with my Genesis yesterday and my gps unit came out DOA...so now I need another gps...good deal on a garmin 201 on ebay....DJ32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Travis, exactly the same prob I've had with every etti esc, bad progression in the power curve. It was like they had zero 20% and 100% power nothing in between to ease into a speed run...I finally gave up using them and went to the T180, castles marine and castle plane esc's converted to marine. I going to try a SF in my new design rigger and see how they hold up to high amp spikes. My castle 240 hit 300amp spikes several times yesterday in my Genesis and almost 7000 watts
running new prop. Gps broke as stated but we could tell it was a good bit faster than my previous 80mph runs. We are guesstimating mid 90's but I am not claiming that till I gps it or radar gun it. I learned something else too, the transom in the Genesis is WEAK, mine is starting to fracture crack. So back to the bench and more reinforcing for it......Congrats on yet again gaining more speed brother....DJ
Tunnels-PS295. Cats-H&M M1 Supercat Daytona rivercat. Monos-DF Cyberstorm HiTech 29. Hydros- Ms K Vac-U-Pickle Custom built 37" shovel 10th scale converted to FE Shadow. Rigger-H&M Evo II. AQ Harbortug recovery boat. Build in progress 37" cf DragboatComment
Maybe I'll sell this esc. Of course I'll be upfront on how it is....I'm sure on a lower speed setup it'll work fine. Mine...no go and I don't care to get used to it. Guess it's motor changing time....Travis, exactly the same prob I've had with every etti esc, bad progression in the power curve. It was like they had zero 20% and 100% power nothing in between to ease into a speed run...I finally gave up using them and went to the T180, castles marine and castle plane esc's converted to marine. I going to try a SF in my new design rigger and see how they hold up to high amp spikes. My castle 240 hit 300amp spikes several times yesterday in my Genesis and almost 7000 watts
Maybe you need to get a carbon fiber daytona and start over. The Genesis hulls look pretty flimsy.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Mine barely catches signal. Tried it all over town, even out on the real boat.... Just a tiny bit of signal.... Even after battery drain/charge and resets....Travis, a bit off topic here but have you had any probs with loosing sat signal on your garmin 201...I did a serious series of somersaults, tumbles, rolls at very high speed with my Genesis yesterday and my gps unit came out DOA...so now I need another gps...good deal on a garmin 201 on ebay....DJ
These thing will be hitting 90mph soon! Wonder if it will be mine? lolWhy are you bothering me? I want to see your boat!
32" CF Rivercat--- built by "kfxguy" (SOLD)Comment
Yours ought to be quick. If it's faster than mine, I'll be happy and pissed at the same time! Lmao!32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I can't tell you how many CC HV240 esc's I burned up running a Prather 240 lol very wise checking temps."Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert EinsteinComment
Travis, now thats scary ! ....I was thinking about getting the CF hull ....I really cant complain, It was a really nasty high speed acrobatic crash. I like those prather SS props, yes they are a bit harder to work, but I think worth the effort....I guess on the Garmin it depends on where you live....Tunnels-PS295. Cats-H&M M1 Supercat Daytona rivercat. Monos-DF Cyberstorm HiTech 29. Hydros- Ms K Vac-U-Pickle Custom built 37" shovel 10th scale converted to FE Shadow. Rigger-H&M Evo II. AQ Harbortug recovery boat. Build in progress 37" cf DragboatComment
I bought 1" wide and 3/8" belt sanders.....makes short work of ss props. You gotta go slow tho. The prather is going to have more speed than any other prop I've tried....I'll bet on it....once the Stuy is were it needs to be. This boat is highly sensitive to strut height....1 mm off and I'll lose 5-7mph!Travis, now thats scary ! ....I was thinking about getting the CF hull ....I really cant complain, It was a really nasty high speed acrobatic crash. I like those prather SS props, yes they are a bit harder to work, but I think worth the effort....I guess on the Garmin it depends on where you live....32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Sean and I both have found that out on our smaller cats, that they are very sensitive to strut adjustment and just a slight size change in props means adjusting the strut accordingly...id like to see more choices in the SS props....DJTunnels-PS295. Cats-H&M M1 Supercat Daytona rivercat. Monos-DF Cyberstorm HiTech 29. Hydros- Ms K Vac-U-Pickle Custom built 37" shovel 10th scale converted to FE Shadow. Rigger-H&M Evo II. AQ Harbortug recovery boat. Build in progress 37" cf DragboatComment
I really want to try a 45mm 3 blade. Or a 45mm with more pitch. Anyone help? Big gap in tne three blade octura offerings. The reason is I don't want to adjust the Dang strut every time I change props. Ugh. I want to be able to throw a m445 on it and cruise if I want.Last edited by kfxguy; 08-24-2014, 08:40 PM.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
