No more pictures as I do not have the boat anymore
My boat had the metal strut that bolted on not just the tube braced like yours
I started out using the nitro flex shaft that had the 1/8 prop shaft on the end
The bearing was getting worn so I drilled it out so I could use the 5/16 and the .150 cable
Be carefull about cutting out the radio box until you have decided how you are going to seal up the cowl to keep the water out
I ended up cutting a piece of pink styrafoam (sp) to put in the cowl so it would sit right above the front edge of the radio box
This sealed up the front part of the boat and I only had to put tape 1/2 way down the cowl and over the front edge
? ONLY IF THEY WORK
