New here does anyone know and good ways to convert the miss bud to brushless?
  • eboat
    • Aug 2007
    • 693
    Originally posted by LOZrunner
    eboat do you have any pics of the under side of your boat and the back? did you leave the shaft stock in it or change it?
    No more pictures as I do not have the boat anymore
    My boat had the metal strut that bolted on not just the tube braced like yours
    I started out using the nitro flex shaft that had the 1/8 prop shaft on the end
    The bearing was getting worn so I drilled it out so I could use the 5/16 and the .150 cable
    Be carefull about cutting out the radio box until you have decided how you are going to seal up the cowl to keep the water out
    I ended up cutting a piece of pink styrafoam (sp) to put in the cowl so it would sit right above the front edge of the radio box
    This sealed up the front part of the boat and I only had to put tape 1/2 way down the cowl and over the front edge
    • LOZrunner
      • Feb 2014
      • 16
      It appears to be in very nice condition. Good choice on the ul-1or similar hardware. I am going to own one of these so I look forward to seeing it be built. what kv 3674 Leo are you using?
      I do not know yet because I am new to electric motors I have been a nitro guy for years.
      • LOZrunner
        • Feb 2014
        • 16
        I was planning on using a thin plastic glass cut and epoxied in? I also was gonna run a new flex tubing and cable I think I am going with a .150 shaft. I have a friend who is really good with a dremel and I was going to have him do the cutting. Do you think I should use fiberglass resin to filling the part on the bottom of the hull where the old tubing is ran? I can post a pic if I didnt make that clear.
        • lenny
          • Sep 2010
          • 4294
          Hey hears a little more info,
          Not sure if you found this info site already.
          http://forums.offshoreelectrics.com/...-Hydro-Q-amp-A
          http://forums.offshoreelectrics.com/...Elam-Race-Prep
          Just took some pictures of my boat.
          Bud hydro hull 007.jpgBud hydro hull 006.jpgBud hydro hull 002.jpgBud hydro hull 003.jpgBud hydro hull 004.jpg
          ? ONLY IF THEY WORK
          • LOZrunner
            • Feb 2014
            • 16
            [QUOTE=lenny;552197]Hey hears a little more info,
            Thanks for the links! your boat looks great. What flex shaft and hard wear are you using?
            • lenny
              • Sep 2010
              • 4294
              It has a PB 1500kv motor and cheap sky wing esc,
              Not sure if that esc will handle the boats size and setup on 4s than maybe 5s.
              I believe it has the stock rudder and bracket,
              And a flat speedmaster 21 strut and .187 flex shaft.
              http://www.offshoreelectrics.com/pro...=ros-spdss-001
              I will be using a x642 prop first for testing to get it up on plane,
              Than see what needs to done for good ride and handling from there.
              Like I said it has never been tested by me yet,
              So I have no idea how it is going to handle and run.
              ? ONLY IF THEY WORK
              • LOZrunner
                • Feb 2014
                • 16
                Lenny:
                I talked to the guy from offshore. He told me to use the leopard and swordfish gear. I wanna hit 70+ but that might be wishful thinking.
                • lenny
                  • Sep 2010
                  • 4294
                  #23
                  Well good luck with that 70mph+,
                  Hears a little something to wet your appetite.
                  ? ONLY IF THEY WORK
                  • LOZrunner
                    • Feb 2014
                    • 16
                    #24
                    My computer has been dumb lately and wont let me load videos. But ill keep posting pictures as my build goes on!
                    • bracka69
                      • Jun 2011
                      • 298
                      #25
                      Here are some pics of my Pro Boat Miss Bud converted from Nitro to Brushless. I removed all the old Nitro hardware and did a CF inlay for the first time. Strut and rudder from kintec and the motor is a Neu 1415 4100kv on 3s 2250mah TP 65c lipos in parallel. Esc is a Swordfish 200a and prop is a Octura X440. image.jpgimage.jpgimage.jpgimage.jpg
                      • lenny
                        • Sep 2010
                        • 4294
                        #26
                        Have any video's of it running yet ?
                        Originally posted by bracka69
                        Here are some pics of my Pro Boat Miss Bud converted from Nitro to Brushless. I removed all the old Nitro hardware and did a CF inlay for the first time. Strut and rudder from kintec and the motor is a Neu 1415 4100kv on 3s 2250mah TP 65c lipos in parallel. Esc is a Swordfish 200a and prop is a Octura X440. [ATTACH=CONFIG]112235[/ATTACH][ATTACH=CONFIG]112236[/ATTACH][ATTACH=CONFIG]112237[/ATTACH][ATTACH=CONFIG]112238[/ATTACH]
                        ? ONLY IF THEY WORK
                        • bracka69
                          • Jun 2011
                          • 298
                          #27
                          Hey Lenny. No videos yet but it moves quite fast. Think I may need to put some more weight upfront.
                          • lenny
                            • Sep 2010
                            • 4294
                            #28
                            That is a lot of kv,
                            Hey your prop dog gap looks very tight at the strut.
                            ? ONLY IF THEY WORK
                            • bracka69
                              • Jun 2011
                              • 298
                              #29
                              Yeah man it is. Runs nice on 3s. It's not tight actually.
                              • LOZrunner
                                • Feb 2014
                                • 16
                                #30
                                Just got her all cut out anyone know a good way to carbon fiber the bottom should i use the lightest i can find?
