does hobby king make a good upgrade motor for pursuit
  • pugman2
    • 236
    #31
    wow getting a lot of conflicting advice . i sure dont want to toast a speed control it was kinda expensive . it has had cooling mod done on it has been dissassembled and sprayed with corrosion x and resealed hoping to not have any issues with it i am also going to set timming down from 7 since what i read about d wind it ran for 3 min everything ice cold including the water i waded in to run it its colder than a well diggers ass down here in ohio
    • lenny
      • Sep 2010
      • 4293
      #32
      Yes, On two 2s packs ran in series to make 4s 45c 6000mah your boat will run a lot better and faster at about 42mph and about 4 minutes of run time.
      Are you using 5.5 bullet connectors on everything in the setup and the lipos,
      Also do you have any pictures of you boat setup that you can post ?
      If so you can connect them together with out using a harness in the setup.
      Read and learn how all this works for your setups.
      http://forums.offshoreelectrics.com/...eries-question
      http://www.offshoreelectrics.com/lipo.php
      And you can also use two 5.5 Y connectors like this for parallel running packs,
      They are not to hard to make if you want to.
      ? ONLY IF THEY WORK
      • pugman2
        • 236
        #33
        lenny i have 5.5 bullets on motor and esc and a deans on battery connections will post pics
        • martin
          • 2887
          #34
          Get rid of the Deans on the battery connectors.
          • lenny
            • Sep 2010
            • 4293
            #35
            Yes that is the first thing you want to do,
            They are a weak link in your setup and will make it run bad.
            ? ONLY IF THEY WORK
            • pugman2
              • 236
              #36
              i sure hate soldering deans i know that alot of people still useing them i used them for now will change over before spring
              • olwarbirds
                Magic Smoke Wizard
                • Oct 2012
                • 1136
                #37
                Besides using just bullets we been using these from castle... http://www.offshoreelectrics.com/pro...as-011-0053-00 I too dislike soldering deans and find these connectors being 6.5mm easier to work with larger gauge wire and easier to connect and disconnect...
                • pugman2
                  • 236
                  #38
                  wow what a difference putting the 2s in series cant wait to get some real batterys to put with this . has anyone ever tried the turnigy 5s 8000 lipos wonder what kind of run time one of those it would be fun to run 2 but they are expensive
                  • lenny
                    • Sep 2010
                    • 4293
                    #39
                    How were your temps on the setup on 4s and how long did you run it for ?
                    ? ONLY IF THEY WORK
                    • pugman2
                      • 236
                      #40
                      ran cool to the touch didnt have a temp gun when i ran it gonna be awhille its really cold here now in ohio lol
                      • lenny
                        • Sep 2010
                        • 4293
                        #41
                        How many minutes did you run it for on the two 2s 6000mah pack in series ?
                        When you charge the 2s packs wright down how many Mah of charge each pack takes,
                        You want to try and have 20% left in the packs at the end of a full run.
                        Also you do not need high C rate packs,
                        30c to 40c is all you really need for that setup like the blue Turnigy 4s 40c 5000mah.
                        When you jump in to the higher MAH packs like the 8000mah than the prices go's up pretty quick,
                        In less you find a great deal on them like half price or something.
                        Also if you are thinking of buying some high dollar cells,
                        May be you should try these out because I hear lots of good things about them for the money.
                        http://forums.offshoreelectrics.com/...rand-Batteries
                        ? ONLY IF THEY WORK
                        • TheShaughnessy
                          • 1431
                          #42
                          Grammar police warning. Lets learn boats and do some English 101 at the same time.
                          Meant to be educational not condescending
                          Write
                          Unless
                          One word: Maybe
                          • pugman2
                            • 236
                            #43
                            my spelling that bad? lenny i want to thank you for the help i greatly apreaciate it . i will try to do like you said i have one of the warning buzzer deals on my set-up . will time it when thing thaw out a bit
                            • olwarbirds
                              Magic Smoke Wizard
                              • Oct 2012
                              • 1136
                              #44
                              ...alot of very good advice here and then .....
                              • TheShaughnessy
                                • 1431
                                #45
                                Guess I'm just bored
