does hobby king make a good upgrade motor for pursuit
  • pugman2
    • 236
    im guessing a 40 mm motor would be a better choice i seen kinetics and ose run 4082s in 2200kv im still wet behind the ears dont see many running 36mm cans
  • Mad Racer
    • Nov 2013
    • 140
    I just ordered a 4074 2200kv Leopard for my H/K Smash Shark to race next year. Had to get the matching water jacket and motor ring. All from OSE here. It's the best upgrade for your $$$ I feel. I think H/K do do a motor but I wanted something in the middle hence the Leopard.
    I'm new to this too but at the end of the day RTR gear is good for running around but not race grade i feel.
    • Peter A
      • Sep 2012
      • 1486
      Does hobbyking make a good upgrade motor for pursuit?
      Good question, you could give the aquastar 3974 2200kv motor a go. I was running one on 4s in a rigger until the motor mount broke out and bent the shaft making it useless. It will push a 442 all day.
      I'm currently running a TP power 3640 2250kv in my pursuit, and race with that against gassers on club days, beats them a lot too!
      • mattmak
        • Feb 2013
        • 21
        I'm using this in both my boats - for the price it has been excellent.
        http://www.hobbyking.com/hobbyking/s..._Inrunner.html
        • jamespl
          • 742
          I had the XK4074 2000kv motor in mine and on 4s with an X642 prop I was seeing just over 40mph.
          • David adorno
            • Dec 2013
            • 7
            I used 36/59 turnigy super edf 1900kv on 5cell and octura detonge and sharpen x prop 442/1.4 pitch running 50mph from hobbi king ease on the pocket too.
            • Heaving Earth
              Banned
              • Jun 2012
              • 1877
              i ran a leopard 3674 in my titan 29 and it kicked major ass.
              how big is the pursuit?
              • pugman2
                • 236
                32 inch vee hull
                • Heaving Earth
                  Banned
                  • Jun 2012
                  • 1877
                  yeah stick with 40mm
                  • pugman2
                    • 236
                    confused about what kv to get i see kinetics and ose used 2200kv stock is like 1650 kv am gonna run 4 and 5s 5800 mah two packs in paralel is what i had planed running a freshly modifiyed t180a esc did cooling mod reamed nipples out alittle with the opened center section i seen in build pages . going to run two water pickups to supply cold water for cooling just have to come up with a good budget motor hobby kings are reasnable if they can compare to the leapards i havnt ran either so i dont have any knowlage on quality other than what i have read .
                    • Heaving Earth
                      Banned
                      • Jun 2012
                      • 1877
                      My best suggestion, is run one cell count and buy a motor catered towards that. pick one
                      • pugman2
                        • 236
                        do they have anything comparable to the 4082 in 2200kv for a boat steve at ose said 40mm would have better torq seen a aqua star 3900kv most of what im seeing in 2200kv is 36mm may try one of the 36mm sugested they are alot cheaper than the leapard and might be able to use factory water jacket
                        • ray schrauwen
                          • 9472
                          What is your goal and what type of running do you want to do?
                          Nortavlag Bulc
                          • ray schrauwen
                            • 9472
                            This is comparable to a leopard from HK: 3974 2200kv
                            This is closer and faster possibly and better customer service: Tacon You can use a Leopard cooler.
                            For the best customer service and the biggest bang for the buck Leo 4082-2200kv: OSE! 1.5Y
                            Don't think just about HK or price, the motors Steve sells at OSE are specifically boat motors with air venting to aid cooling and a free cooler to boot. You couldn't get a better deal with his kind of service anywhere with the exception of maybe ML Boatworks, Keith Bradley boats and a few others that work hard and go the extra mile while supporting fellow countrymen.
                            Nortavlag Bulc
                            • TheShaughnessy
                              • 1431
                              If you want to run 4 and 5s I would recommend 1800kv motor. You would still need to prop accordingly though. I had a HK 4074 2000 kv in mine and later upgraded to a castle 1515 1y and the difference was really noticeable . Just remember its a 30-50 dollar motor for a reason
