can i make my miss gieco 24 faster with out going brushless
  • Wes Rose
    Banned
    • Dec 2013
    • 68
    can i make these boats faster and not go brushless
  • photohoward1
    • 1610
    Why would you want to? There is so many choices. Oh to answer the question no you can't. There really is not an alternative anymore. Brushed was a pain in butt. Brushes, Inefficiencies, heat and only one very reliable controller.
    • Heaving Earth
      Banned
      • Jun 2012
      • 1877
      Use lipos if you aren't already. Good burst of speed there
        Brushless is well worth it.
        • Wes Rose
          Banned
          • Dec 2013
          • 68
          my esc os 60.amps.can go uo.to.an 8 cell battery.it says compatiable with 6 to 8 cell batterys. ps will lipos be ok on a brushed motor
          • photohoward1
            • 1610
            Yes. Depends on the motor and the voltage. What did you have in mind?
            • ray schrauwen
              • 9472
              Howard it's a 15 turn sealed can motor. They say it's about a 2200kv motor but, you can't really give a brushed motor a KV rating, maybe a max voltage rating.
              ESC is a 50 amp 6-8 cell. 8 cells is fine but, check temps often.
              One upgrade to get more speed is to use a metal prop like Octura or a CNC prop of same size and pitch. The CNC props need little or no sharpening. Stock prop is 34mm so an x435 would work or this 430 x3 blade would work depending on shaft size for prop and with that I am lost??? I have no idea what size prop shaft they used????
              Nortavlag Bulc
              • Heaving Earth
                Banned
                • Jun 2012
                • 1877
                Wouldn't 4s be max voltage you want to run in it then?
                6 0r 8 will be a fire no?
                • Heaving Earth
                  Banned
                  • Jun 2012
                  • 1877
                  Oh I see 6 or 8 Nimh cells.
                  Which is about equivalent to 2s or 3s lipos.
                  I run my brushed summit on lipos all the time. Wayyy more power
                  • Heaving Earth
                    Banned
                    • Jun 2012
                    • 1877
                    Dude,get a 3s lipo and a lipo cutoff. Plus a prop, you'll see a good increase in speed
                    • Wes Rose
                      Banned
                      • Dec 2013
                      • 68
                      thanks for all the help.guys.i think im gonna like this site
                      ill make a video tuesday when i run the boat.how can i upload it on here
