FC300A ESC Parts Information Wanted
  • Alexgar
    • Aug 2009
    • 3534
    Did you try with an external bec and motor and see if it will spin
    • capnswanny
      • Feb 2012
      • 817
      I did, got one beep when I plugged it in.....pause.....10 beeps.......pause......10 beeps...etc
      No throttle response, played with throttle settings, rev, no joy. But, no smoke yet :)
      This is NOT a toy?!?
      • Rocstar
        Joel Mertz
        • Jun 2012
        • 1509
        Corey, I'll send 3 of them to you. I'm not too worried about them. Fix them...blow them up..whatever.
        PM me your address.
        • capnswanny
          • Feb 2012
          • 817
          Joel, Got the Speedos...Thanks!
          Looks like 2 have some failed FET's and controllers. The 3rd looked good but for some corrosion on the controller card. I'm going to enjoy seeing if I can fix these.
          I appreciate your help buddy!
          Corey
          PM me your address.
          • Alexgar
            • Aug 2009
            • 3534
            Corey
            got pics of the other one just wanted to take a look at them
            • Rocstar
              Joel Mertz
              • Jun 2012
              • 1509
              Corey
              No problem. I have 3 others that are in use right now. After those ones failed, I coated these with liquid electrical tape. So far so good.
              • Rocstar
                Joel Mertz
                • Jun 2012
                • 1509
                • Alexgar
                  • Aug 2009
                  • 3534
                  #23
                  Did you use the.spray type to waterproof or paint on
                  • Rocstar
                    Joel Mertz
                    • Jun 2012
                    • 1509
                    #24
                    Yes, spray on type.
                    • capnswanny
                      • Feb 2012
                      • 817
                      #25
                      Well here's my first DigiKey order:
                      (4) IRS2103SPBF - IC DRIVER HALF-BRIDGE HV 8-SOIC
                      (6) IRFS3004TRLPBF - MOSFET N-CH 40V 195A D2PAK
                      (3) TAJC107K010RNJ - CAP TANT 100UF 10V 10% 2312
                      Let's see where that gets me. These are the visibly bad components on the 4 ESC's. I'm still going to take some time to read some of the circuits and hope I don't find anything else bad. It really helps that you sent me three of the same boards. Guess I need to get me a programming card on order :)
                      Corey
                      • Alexgar
                        • Aug 2009
                        • 3534
                        #26
                        Cool hopefully you get them all working then you can sell me one
                        • capnswanny
                          • Feb 2012
                          • 817
                          #27
                          Hehehe, and I don't have a motor or vessel that requires an ESC this size.....just planning ahead
                          • Alexgar
                            • Aug 2009
                            • 3534
                            #28
                            Yea never got a chance to try one and am a little apprehensive to try one while so many horror stories floating around
                            • Rocstar
                              Joel Mertz
                              • Jun 2012
                              • 1509
                              #29
                              I hope you can make something work. These ESCs appear to be extremely susceptible to moisture. Just a small amount of condensation under the shrink wrap would take them out. So far the testing of 3 others I covered in liquid tape in two different boats (one twin and one single) is going well. However I just crashed and submerged the twin, so we will see what happens after is all dries out.
