Why did this happen? MG29 + SK180 blow up w/ pic!
  • blowNover
    Flounder
    • Nov 2012
    • 189
    #31
    It sounds like a few guys are saying sometimes you just get a lemon. And yes the t180 and seaking 180 are the same.
    • blowNover
      Flounder
      • Nov 2012
      • 189
      #32
      So I have to revive this thread! Check this out my sk180 let out the magic smoke! And I have to say it was in a very dramatic fashion. And this was a dialed in setup that's been ran a ton of times. I have no clue what in the world happened. Just had to kind of laugh.
      • Savage Skidoo
        • May 2011
        • 332
        #33
        I attach an external BEC , my 1 st T-180 went up like that with no bec and kaboom on 6s
        www.facebook.com/Boaters and Crawlers Durham
        Durham Off Road Rc Club - www.dorc.ca founding member
        • blowNover
          Flounder
          • Nov 2012
          • 189
          #34
          Yea it took out my receiver as well I'm sure.
          • MrEvoMan
            • Jun 2009
            • 48
            #35
            That's exactly what mine looked like. Took out my receiver as well.
            • Savage Skidoo
              • May 2011
              • 332
              #36
              I use bec's now in all my T-180 6s setups .
              • silversurfer
                • Dec 2011
                • 11
                #37
                them blood 180 esc arereally funny esc got a mind of there own
                • ray schrauwen
                  • 9475
                  #38
                  It's not that big of a prop on a Geico. I ran a x448 D/T with 1800Kv AQ motor & HW120A esc and it was on the edge for heat after 6-7 laps on full course.
                  Prop hub is level with sponson bottoms. I don't see a 3674 1900kv having a problem with the heat since it's larger and the esc was 180A rating. It's just a bad egg in the batch IMO.
                  Originally posted by iop65
                  i do not understand that this hull would be running great with a 48 mm cnc prop??
                  that is way to big for a 29" hull
                  and it is hard to believe that the 3674 can was pulling this without problems ,1900KV 4s?
                  the only way you can keep a hull this small with that motor and prop running reliable,save and cool is when you where using only a part of the prop in the water!
                  where is the point in that?
                  a 48 mm on a 29"hull
                  Nortavlag Bulc
                  • iop65
                    • Mar 2013
                    • 367
                    #39
                    the topic starter was asking in another tread ( proboat )about handling problems with this boat , so i don't think we have to go further into using a 48 mm prop on a 29 inch boat
                    but if you like this , and it works for you ,no problem for me.....
                    • iridebikes247
                      • Dec 2011
                      • 1449
                      #40
                      Cheap, small motors become really inefficient when strained. The t180 is a really good esc and holds up better than a lot of the expensive "get what you pay for," escs and I say this after watching a lot of escs burn up. I know very little when it comes to props for the smaller single cats but 48mm sounds really big for that boat. I think if you prop down you'll be good, personally I'd ditch the motor too and get another one say a leopard 4074. Not that you're lacking in the power department sometimes with the power systems from china stuff fries because the quality control is low. I have a lot of leopard motors and for the price you can't beat these things but I know I'll have to change the bearings and stuff to keep them running ok.
