Batteries getting HOT
  • gixx1k2
    • May 2013
    • 277
    It's the new red one
    Michigan Fast Electric SAW Club
    • gixx1k2
      • May 2013
      • 277
      I don't have this problem in my revolt or my delta force
      • Heaving Earth
        Banned
        • Jun 2012
        • 1877
        I feel like the aq electronics are better than pb
        As far as the delta force, what's even in it?
        • gixx1k2
          • May 2013
          • 277
          Neu motor and seaking 180a
          • TheShaughnessy
            • 1431
            What is hot? Let's talk numbers
            • gixx1k2
              • May 2013
              • 277
              Didn't bother to check since the pack was smoking. My charger brought them back to 8.4v though
              • boredom.is.me
                • Jun 2009
                • 595
                You probably killed your batteries. 3.1 volts per cell is fatal. You also say that they are smoking. Just because they reach full voltage on a charge does not mean anything. I've had small batteries that reach full voltage, yet fail to even power LED's.
                • gixx1k2
                  • May 2013
                  • 277
                  I figured they're fried but I'm gonna test them before I get rid of em
                  • iridebikes247
                    • Dec 2011
                    • 1449
                    Packs don't really heat up much until you go below a certain voltage. When the batteries are out of the boat at home and read some 3.1v, underload forget it they were like 2.6v. When you put a pack on the charger at home you should really get like 3.7 volts. Did the packs puff?
                    • gixx1k2
                      • May 2013
                      • 277
                      No they didnt puff, they're still hard
                      • jeffrey1
                        • Mar 2013
                        • 37
                        they should not get really hot. i use thunderpower 5300 65c pro race and they stay pretty cool.
                        • 96motorhead
                          • Apr 2013
                          • 38
                          #27
                          I had the identical problem. You are running the batteries to low. Don't go below 3.8v per cell. I run my 5000mah 35c 2s lipos for 5ish min and then stop. They stay a bit warm but not hot. If they did puff a tiny bit then they will start doing it progressively worse. I ruined 1 battery from running it to low in my blackjack. It almost went up in flames today it puffed so bad it was easily twice it's size, I had never seen anything like it.
