3674 2200kv motor wire hot. help
  • Heaving Earth
    Banned
    • Jun 2012
    • 1877
    #31
    Originally posted by hnm738
    today I tried a different esc I had lying around. it is 125a esc, this esc has the correct timing on default.
    http://hobbyking.com/hobbyking/store..._125A_ESC.html
    I installed 2 caps 35v 1000uf
    ran for 3mins and then got stranded in the middle of the pond, after retrieving the boat, the ec5 connectors between the battery and the esc melted and welded together, the negative lead unsoldered itself.
    Where does it say the default timing setting?
    • hnm738
      • Feb 2013
      • 24
      #32
      default timing is 1 degree
      • Heaving Earth
        Banned
        • Jun 2012
        • 1877
        #33
        Not what I asked. I asked "where"does it say default timing setting?
        • lenny
          • Sep 2010
          • 4294
          #34
          Hears a link to a good setup for that boat hull.
          http://forums.offshoreelectrics.com/...-Princess-boat
          http://forums.offshoreelectrics.com/...rincess-maiden
          I am not sure what speeds you are getting with yours with no gps or video's of it running.
          So with no video and no pictures of the whole boat setup with hardware on the transom and drive line,
          Like I asked you to post some time ago.
          So we could try and help stop you from burning your boat up.
          But the first thing I would buy is the 5.5 bullets.
          Than you should read and learn about what works,
          Than if you want to try and mod a setup you will have some idea what is going on with it.
          ? ONLY IF THEY WORK
          • sundog
            Platinum Card Member
            • Feb 2009
            • 878
            #35
            Here. The choices with the asterisks are the default settings. He's just pushing that motor too hard. Need a 40mm can with lower kv on higher voltage (more cells). If you have 4s lipos, go with an 8S arrangment.
            Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
            • Heaving Earth
              Banned
              • Jun 2012
              • 1877
              #36
              Thank you. Lol
              • hnm738
                • Feb 2013
                • 24
                #37
                i'll get a video of the boat running next weekend, had my iphone in the boat and it showed 39mph.
