Yep you have a very short jacket on the motor but worst of all you should take the water in to the jacket in the lower nipple & out the higher one (the way you have yours the jacket dosnt fill with water before it exits. As said you should also cool the esc first then the motor.
3674 2200kv motor wire hot. help
What make 120a esc is it and did you change the connector to 5.5 bullets yet ?
You can always add more caps to the esc to help with heat if you need to,
I just added one to my seaking 120a esc for my modded 36"shockwave to fe.
Also did you get any video of it running yet ?
What is the timing set at on the esc ?
What make are they cells ?
Are you running in parallel with the 4s packs or just a single pack,
And how many minutes of run time are you getting on the 4s 30c 5800mah cells ?Comment
I just ordered 6mm bullets should be here in 2 weeks, still have the 5mm ec5 connectors
the esc im running is hobbyking 120a http://hobbyking.com/hobbyking/store...C_4A_UBEC.html
I don't have a programming card so I don't know what timing it has?
I run just a single 4s and the batteries are again from hobbyking "zippy" brand, im getting around 4mins but I always bring the boat in below the LVC kicks in to check on the temp etc.
no vidoes unfortunately.Comment
You only needed the 5.5 bullet and you should get a program card for the esc to set it up right.
Because you do not know where anything is set at on that esc,
And that is a bad thing not to know.
Save your self some money and get the 5.5 and and the card for the esc,
For 6.25 or burn things up.Comment
It's not a question of poles as much as wind type.
Your motor is a d wind so you want 0-3 degrees. 15 is gonna be way too much and cause heat issues.Comment
today I tried a different esc I had lying around. it is 125a esc, this esc has the correct timing on default.
http://hobbyking.com/hobbyking/store..._125A_ESC.html
I installed 2 caps 35v 1000uf
ran for 3mins and then got stranded in the middle of the pond, after retrieving the boat, the ec5 connectors between the battery and the esc melted and welded together, the negative lead unsoldered itself.Comment
[ATTACH=CONFIG]99390[/ATTACH]
on the m445 the motor and esc and caps were roughly 120F, the motor wire is 165F, Lipo batteries were 140F
esc to battery wire is about 10cm and battery also has about 10cm wire
I did try to shorten the motor wire, when I cut the plastic covering, the wires had a red tint on it and I couldn't solder on it so I just left it.4s batteries, im running everything with ec5 5mm connectors (motor 3 wire is ec5, battery/ esc is also ec5) i'll try to get some pictures tonight.
my boat is about the size as the pursuit, the only difference is it run much wetter than a pursuit due to weight, most of the hull is still in the water at speed, where as the pursuit is usually 1/3 in the water at speed.
If your Lipos are at 140* (F), they are way too hot.
When you say warm (ESC body and motor), keep in mind that these places cool down before you are able to get to them, by the time you get the boat out of water and open the hatch, they are going down temp wise. The caps retain their temp longer.
Maybe your motor can take the heat, but the amp draw is heating up the rest of the system. You need to prop down or change to a lower kv motor, this is like putting a small engine in a heavy/large car and you need to run in 3rd gear just to stay on the highway, it will over heat, along with many other unpleasant discoveries.Too many boats, not enough time...Comment
I currently like the speed this boat is getting with the 2200kv and 45mm prop
if I purchase this 200a esc will it solve the heating problem?
http://hobbyking.com/hobbyking/store..._125A_ESC.htmlComment
http://hobbyking.com/hobbyking/store..._125A_ESC.htmlToo many boats, not enough time...Comment
this is the 200a esc http://hobbyking.com/hobbyking/store..._200A_ESC.html
I tried to prop down to 42mm and the boat takes a long time to get on plane.Comment
