That is correct, within a rpm range that works. Unloaded I would say 22-32 thousand which is 1500-2200kv, for a 4S tunnel. You may want to bump your timing to 10 degrees for the AQ 2030. It also appears you might need a little more positive trim. Go up a little at a time to free the boat up and back down when it gets too nose high. Those HK motors can be good but I feel it's worth a few bucks more to buy quality. AQ is a very good motor. Keep us posted on your results.
Mic
Mic
