For someone looking to get there first tunnel hull would inboard be an easier set up to begin with? I would love to run outboard just getting it tuned in
HELP!! with recreational FE tunnel build
Like you I couldnt make it to the Boat Ramp Cold front blew in, Wind is crazy.................I want to try the new motor out 36x74 2200kv w/42x55 (same prop) that 36x30 proboat motor just didnt have it .
DaveG1 Whip , Insane F1, FE VS1
LSMBC Dist 7 Namba 1759Comment
I think you would be better to go with an outboard. Most of these tunnels have very narrow interiors and would be a huge PITA to get an inboard installed.Comment
Plus they are just not designed to run an inboard setup, I suppose you could rig up some kind of steerable outdrive to get the prop back far enough. Anything is pretty much possible but the big question is it worth it when you can just bolt on an outboard unit and do it "right"
There is no difference between tuning an outboard or an inboard, same kind of adjustments, same effects. Both take time and trial end error
To be honest it is pretty easy to make changes on an outboard tunnel if you have a good motor mount. All you have is up and down and tilt! No rudder to adjust.If my boats upside down then who owns the one I thought I was driving the last two laps?Comment
If its already set up that way then someone has done the hard part. There are tunnels that run with inboards but I couldnt honestly say whether or not they are designed for inboards or have just been converted. What boat is it you are looking at?Comment
Kendt that looks awesome!!! I hope mine looks half as good. Hope it runs as good as it looks:-) Have fun thats what its all about right..Comment
Got it out for a quick test today. WOW this boat is going to be awesome. It flies along like a dream. The 7.5 unit is a perfect match. Didnt notice any ill handling at all. Still more testing needed and I need to go over it again to check for leaks. First run the set up is very close.Comment
Just bought a 36" k&m tunnel hull all hardware just need electrics already set up as an inboard was going to go 4082 prolly 1600kv with swordfish 200 amp speedy already have programmming gear otherwise get t180 and hoping to run on 5s as i already have 4 50c 5000mah and maybe 3 blade 46x1.8. I like the neu motors but i think I will go with leopard for cost, any tips or recommendations (seller ran a combo similar and had great results)
tunnel1.jpg?What's life if you ain't having funComment
Nice looking boat. Congrats. A leopard is a good choice for motor. You might also want to look at some from hk. They have got some great motors at very resonable prices. I have not had much luck with 3 blades on tunnels but being an inboard it might work better. a 445- 447(2) is right around the proper size. Also you might want to look at the sirius line of motors. They are simiar in price to the leopards but higher wattage.Comment
What about TP they are same specs but little bit cheaper
