HELP!! with recreational FE tunnel build
  • ChoppyOne
    Just Addicted !
    • Apr 2013
    • 121
    Thanks Marko............. I have been reading thru the thread and noticed the first boat Darin did he had installed the esc in the same location but have noticed the box for the lipo......I think I will reconfig here even thought the boat ran very well for the first voyage today at the boat ramp .
    Dave
    G1 Whip , Insane F1, FE VS1
    LSMBC Dist 7 Namba 1759
    • kendt
      • Jul 2011
      • 557
      That hull looks cool with the stiletto motor.I would have like to do the same but i dont think its up to the task for 6s. The HK hornet also comes with the esc outside the radio box.If its 100% waterproof its fine. Tunnels do blow over so you wanna make sure everything is sealed. I made some changes to mine. There is a pic of the finished setup in the other tunnel thread. Hope to test tommorrow.
      • ChoppyOne
        Just Addicted !
        • Apr 2013
        • 121
        lil done today......Im going to build the longer box to mount all inside but she does run good like this and CG's at 8"
        • kendt
          • Jul 2011
          • 557
          Sonds like your on the right track. You'll have some peace of mind with a larger box. Knowing everything is protected.
          • marko500
            • Aug 2008
            • 861
            Dave I build the boxes out of thin poster board or cardboard. Then lay my templates on the wood and trace them and cut them out. The cardboard is easier to trim to fit and to make sure everything is going to fit inside.
            • ChoppyOne
              Just Addicted !
              • Apr 2013
              • 121
              Great Idea...........Thanks
              • ChoppyOne
                Just Addicted !
                • Apr 2013
                • 121
                need too check it out
                • kendt
                  • Jul 2011
                  • 557
                  #23
                  Ya that is a good idea. I also read somewhere where they guy carved one out of foam then wrapped it with glass cloth. Then he removed the foam. pretty cool idea !
                  • marko500
                    • Aug 2008
                    • 861
                    #24
                    I like the foam/glass idea too. One of the guys I know has built cowls for a hydro like this. Only problem with me doing glass work is the mess I make. Seems like when I do glass everything within 6 feet of my project gets at least some epoxy on it.....including me, my hair, etc. lol
                    • Mulisha
                      • Apr 2013
                      • 241
                      #25
                      Sorry to hi-jack what's the pro's and con's to inboard v outboard?
                      What's life if you ain't having fun
                      • BHChieftain
                        Fast Electric Addict
                        • 1969
                        #26
                        Don't be surprised if the boat still rips pretty fast on UL1 with 440 prop... I "thought" I would prop down with that to slow the boat down for my son and it is still a rocket... my racing prop is now actually an m440, and my recreational prop is down to x437.
                        Here's the boat on UL1/m440
                        This post has the OPC On UL1 down to x437
                        http://forums.offshoreelectrics.com/...Miss-Geico-OPC!
                        Chief
                        • kendt
                          • Jul 2011
                          • 557
                          #27
                          Inboards require a separate rudder prop shaft and strut but you can typicaly maintain higher speed in the corners with an inboard. outboards are self contained units (shaft, strut,rudder all in one.) But the steering is trickier because you are re directing thrust, not just water so you have to slow down a bit more to navigate the turns. Other than that an outboard is just way cooler IMO.
                          • kendt
                            • Jul 2011
                            • 557
                            #28
                            Wasnt able to get it to the pond today but did some decorating.
                            • siberianhusky
                              • Dec 2009
                              • 2187
                              #29
                              looking good Ken! Can't wait to see this one running!
                              • kendt
                                • Jul 2011
                                • 557
                                #30
                                Ya i'm itchin to try it out for sure.
