Mono rolling help
  • SirBudman32
    • Aug 2011
    • 625
    No that is the Port side, ( the boat left the port).
    Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
    • SirBudman32
      • Aug 2011
      • 625
      here is mine. You seen the video of it, Next to my daughter's modded Mini Mono it probably my best running boat.
      2012-11-09 14-30-22.473.jpg2012-11-09 14-30-47.093.jpg2012-11-09 14-31-42.640.jpg2012-11-09 14-32-27.691.jpg2012-11-09 14-33-04.759.jpg
      • gfm1135
        • Aug 2012
        • 170
        Oops. Was at work and read that to quick. Thanks. I will try and move it the starboard side and remove some more lead. Appreciate the advice.
        • SirBudman32
          • Aug 2011
          • 625
          I have al the lead the give you with the boat in the tunnel. One at the back and one up in the front.
          • gfm1135
            • Aug 2012
            • 170
            Mine did not come with any lead. I used wheel weight lead. Any idea how much you have in there?
            • SirBudman32
              • Aug 2011
              • 625
              two strips at 40 oz each
              • gfm1135
                • Aug 2012
                • 170
                Damn. 5lbs?
                • SirBudman32
                  • Aug 2011
                  • 625
                  #23
                  OZ, not LBS
                  • gfm1135
                    • Aug 2012
                    • 170
                    #24
                    2 strips at 40 oz each is 80oz = 5lbs
                    • SirBudman32
                      • Aug 2011
                      • 625
                      #25
                      grams
                      • znus
                        Broke, as usual
                        • Jun 2011
                        • 120
                        #26
                        I have almost the same hull with an Etti 2970 3000kv on 3s & T120. It rolls alright
                        As others have mentioned - your boat (and mine) is way overpowered. I run a X438 prop on mine which does nothing to the motor & esc in terms of heat but the hull cant take anymore. You have to balace it with the rudder, so to speak. I tried an X642 just to find the limit on the motor but there was no way I could floor it. On half throttle the hull started to REALLY turn and I had to back down.
                        That being said - the hulls are pretty decent and imho easy to work on considering the size.
                        25" Arrowana with Etti 2970 3300kV. RCMK Flying Cat with twin HOR Outboards. 2 x SSS 4092 2140kV. Faluga 45" with Leo 56110 620 kv on 12s.
                        • gfm1135
                          • Aug 2012
                          • 170
                          #27
                          Sirbudman, what motor are you running in yours.
                          • SirBudman32
                            • Aug 2011
                            • 625
                            #28
                            Had a Turnigy 2223 2900 out runner in it in the video. Right now it has a 2835 2700 in runner in it and it is a lot slower. Going to be putting the out runner back in it. I'm running it on 3s 2200 batteries turning a 32 and 35mm prop.
                            http://www.hobbyking.com/hobbyking/s...er_2900KV.html
