Hi guys. Need some advice. I have a 22.5 mono running a Leo 2860 3400kv, 120a ESC, 3s lipo turning a 438 prop. It takes a bit to get on plane and when it does plane, it rolls at 3/4 throttle. Any suggestions? Thanks.
Mono rolling help
What hull is it?
the motor and esc is right, I ran the same setup in etti chaser and its a fast setup, i ran it on a 37.5mm propFC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
Popeye Hydro T600 1400kv 6s1p -
Any pictures of how you got it setup? sounds maybe its down to battery placement! not that i'm an expert on that hull. its a v hull right?
take a picture it helps when you can see what's what.FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
Popeye Hydro T600 1400kv 6s1pComment
Deep V hull or steped hull ? I thought that hull is a deep v
my lipo is on the flood chanel side on a steped hull, but i think with a v hull you run packs either side of the motor.
what size lipo you running?FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
To much prop-motor42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)Comment
What is the CG at with the battery back there and all that lead or whatever in the flood chamber. Should be 27-30% of the hull length forwards from the transom.
About 6 1/2 to close to 7" forwards if my quick mental math is close.If my boats upside down then who owns the one I thought I was driving the last two laps?Comment
I removed most of the lead. Still trying to roll yet not as bad. I think Bass is right, just to much motor. I am about to gut the boat. I think maybe start a new build with a better and bigger hull. This was my first build and have learned (and spent) a lot. With big hands and limited space it is very difficult to work on and doesn't allow for many options as to equipment placement. I think it would be wiser to put the money into a better hull. Your thoughts? Thanks.Comment
Smaller motor / prop42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)Comment
Buy a Etti Envoy or Chaser hull, and use that motor and esc and lipo, run on a wire drive setup. 37.5mm prop 39mm max you will be happy chappy.
this was a Etti Chaser i once had, on them same setup as yours only a 39mm prop it ran 5 minutes + at full throtle.
Try moving your esc to the left starboard side of the boatModified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).Comment
