Cheetah Single motor recomendations
  • Chilli
    • Jan 2008
    • 3070
    Dooh!!! I guess you can sand the tips of the sponsons and fill with a little epoxy to make it P Legal.
    Mike Chirillo
    www.capitolrcmodelboats.com
      If I get a Cheetah, I was thinking 4092/1300kv or maybe 1390kv on 6S for heat racing. Higher voltage= cooler running and less amp draw. Your thoughts Jay?
      Either Kv should work fine on 6S. I race a Neu 1527/1Y (1250Kv) in a SprintCat40/60 on 6S and it runs great.
      BTW the SprintCat is 34.5" long, not legal for P without surgery....
      • Chilli
        • Jan 2008
        • 3070
        Thanks. Jay.
        I knew the Sprint cat was a half inch over with the shoebox mounting of the the deck. If the Cheetahs is a splash of the Sprintcat bottom, I figure it was going to be close to 34" with a clam shell deck seam.
        Mike Chirillo
        • b20btec
          Senior
          • Aug 2011
          • 252
          I have a cheetah, here's my setup below. I have never GPS'ed it haven't gotten around to datalog it but I can't be happier. I'm never too worried and this setup is for sport running and really reliable.
          4092 1730KV
          FC 240HV
          5S2P
          M447
          • 100 mph jet boat
            • Apr 2012
            • 121
            Originally posted by Chilli
            The Genesis is a much narrower hull than the Cheetah, though I thought the 4074 was comparable to the Neu1515.
            Your thoughts Jay?
            Don, can you get me the exact length of the hull? I need to know if it's over 34 inches. I think Carl said its a tad over.
            Did you already have a 4082 1600? If so, I think it would work great on 5S.
            bill is right 34-1/6
            yes i had 4092-1600
            I was going to build a FC Daytona and made a deal for the motor and esc first. Carl told me about the hulls thats why i got the Cheetah, i wanted one that would turn nice.
            • sturco
              • Jul 2011
              • 93
              keithbradleyboats.com Keith built my single Cheetah 5S2P, leopard 1600, 4092. Check out his site and many posts on his forum for motors.
              Steve
              • SirBudman32
                • Aug 2011
                • 625
                Yes the Genesis is a narrower hull but it is also 3 inch's longer and heaver then the Cheetah hull. The CC1515 is just a touch bigger than the 4074. All I can say is next summer I will see as I am going to run the CC1515 2200 T-180 on 4-5s batteries with a m445 and will see how it goes.
                Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
                • keithbradley
                  • 3663
                  #23
                  The Cheetah will take A LOT more power than the Genesis to get the same speeds. Jay's reccomendation of a 50mm prop and 4092/1717/1521/1527 on 6s is a pretty good one for a Cheetah.
                  www.keithbradleyboats.com
                  • Basstronics
                    • Jun 2008
                    • 2345
                    #24
                    Im a bit baffled by this thread.
                    Castle 1515 is 40mm x 75 lg. Close enough to 4074. It is rated at 120A 25V just like the Leopards. No wattage is given but who cares what it can take- its what hes going to give it. Amps X Volts = power (with no losses). Lets just assume that 120A @ 5s (18.5V) = 2220 watts which converts to dang near 3 HP.
                    Two motors, same ratings- one higher quality but its not enough?
                    4092 steps it up quite a bit now though...
                    Next. Longer hull = more surface in the water/drag. Now the Cheetah is wider, but how much more hull is actually in the water? I would think this comes out in the wash.
                    But what do I know. Just seems logical in an unlogical world.
                    • keithbradley
                      • 3663
                      #25
                      The Cheetah is a much larger boat and required a larger prop to lift it out of the water.
                      First, I don't think a Genesis/Daytona has a longer splash than a Cheetah. Second, there is FAR MORE surface area on the bottom of a Cheetah. It is perfectly logical.
