Cheetah Single motor recomendations
  • chipgibbs
    CG3
    • Aug 2012
    • 164
    I just ordered a Fighter Cat Cheetah and plan to build it with a single motor and 4s setup.
    What would be a recommended motor for this size / weight hull? I'm not sure if I'm going to race but, would like to see high 50s if possible.
    Thanks for any advice
    ChipG
  • dana
    Banned
    • Mar 2010
    • 3573
    What's your budget?
    • 100 mph jet boat
      • Apr 2012
      • 121
      check this out
      lots of good info
      • 100 mph jet boat
        • Apr 2012
        • 121
        u saw my cheetah i have this strut and rudder
        hydro .187
        http://www.offshoreelectrics.com/pro...os-large-strut
        rudder
        Kintec racing 5 inch Rudder Offset Base w/ Dual water pickup
        • chipgibbs
          CG3
          • Aug 2012
          • 164
          I really hand't thought about budget, I'm not going to buy it all at once. I just need some ideas / goals. Once I have a motor decided upon, I''ll figure out how to get it, even if I have to sell off other stuff.
          Chip
          • SirBudman32
            • Aug 2011
            • 625
            I"m getting ready to start building my Cheetah hull as well. I will be using a CC1515 2200 on 4 and 5s batteries.
            Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
            • 100 mph jet boat
              • Apr 2012
              • 121
              what's ya want for that gps J/K
                • 8012
                A 34" cat is a little large for a 1515 motor although it works with a smaller prop. You'd do better with a 40mm motor like a Leopard 4082 or a Neu 1521 with Kvs around 2000 or even a Castle 1717. That will get your speed goal of high-50s but be easier to prop and will give lower temperatures. It is still a raceable setup.
                • 100 mph jet boat
                  • Apr 2012
                  • 121
                  This is a copy and past from Choppertony / Properchopper on here
                  After three days of nail biting (after delivering the boat) I got the call this morning. Success ! Cameron ran the boat on totally glassy water and got 57 mph on the GPS . Being my first Cheetah build, and being asked to come up with a 4S2P package with decent sport speeds & runtime, I made an educated guess on the setup and it worked. Given that all the Cheetah's I've seen here use bigger motors (4092's) on 6S, I gambled on the current setup and I'm pleased it worked out. I went with the 4082 to be more conservative on amp draw for a 4S setup thinking the speeds might not be enough, but 57mph on glass is rockin' with more available when the water kicks up some and loosens the hull (plus more prop is likely do-able).
                  Here's the setup :
                  Leopard 4082 2000KV
                  T-180 at 3.75 deg. advance
                  Oct X447/3
                  Dinogy 4S2P 5000mah 65C/130C packs
                  CG @30%
                  Strut (shaft centerline) @ 3/16 up
                  Strut @ 3deg positive (lifts nose under power, allows it to drop down to turn)
                  I'd reccomend this setup for an alternative to the 6S setups for those invested in 4S batteries and looking for good sport performance. I race seven "P" (4S) classes now and may very likely build this same setup for myself to race in P-Offshore. Hmmmm...
                  • SirBudman32
                    • Aug 2011
                    • 625
                    The 1515 worked good in my Genesis.
                      • 8012
                      This is a copy and past from Choppertony...
                      That sounds like a near-perfect setup. Boats this size race better with props bigger than 45mm; I've run 50mm 2-blades on a similar setup. Better acceleration out of the corners and in rough race water. Little props belong on little boats......
                      • SirBudman32
                        • Aug 2011
                        • 625
                        The CC1515 2200 is a a 40mm x 75 mm motor.
                        • Rumdog
                          • 6453
                          a 1515 wont cut it. I mean, it will, but you'll be very limited with prop size. I'd definately go with a 6s setup, and a 4082 Leo at minimum.
                          • Chilli
                            • Jan 2008
                            • 3070
                            The Genesis is a much narrower hull than the Cheetah, though I thought the 4074 was comparable to the Neu1515.
                            If I get a Cheetah, I was thinking 4092/1300kv or maybe 1390kv on 6S for heat racing. Higher voltage= cooler running and less amp draw.
                            Your thoughts Jay?
                            Don, can you get me the exact length of the hull? I need to know if it's over 34 inches. I think Carl said its a tad over.
                            Did you already have a 4082 1600? If so, I think it would work great on 5S.
                            Mike Chirillo
                            www.capitolrcmodelboats.com
                            • bill34207
                              • Dec 2009
                              • 2553
                              Originally posted by Chilli
                              Don, can you get me the exact length of that hull. I need to know if it's over 34 inches. I think Carl said its a tad over.
                              I'm not Don but mine measured at 34-1/16" from transom to sponson tip. Just enough over to make it illegal for P unless you take a sanding block to it.
                              My YouTube Vids
