More Mystery Controllers
  • Steven Vaccaro
    • 8721
    #46
    found the live mode record option!
    • jeff180
      • Jan 2008
      • 150
      #47
      so how soon do you think we can see the 200amp?
      sad
      • calcagno45
        • Mar 2008
        • 1006
        #48
        Not trying to steal Steven's business but china dealers have them.
        • ReddyWatts
          • 1711
          #49
          We get better service from Steven.
          ReddyWatts fleet photo
          • Steven Vaccaro
            • 8721
            #50
            but its not 200 amps continuous. if i have it, it will be rated for what it is.
            • RCprince
              • Jul 2007
              • 1637
              #51
              Why get them from China when Steve will get them to you in about 3 days...when in stock.
              • Flying Scotsman
                Fast Electric Adict!
                • Jun 2007
                • 5190
                #52
                Ye gads, I would never state that on a forum that OSE funds.
                Steven has tested the 200 amp esc and states it is capable of 125 amps. This is responsible selling of a product!!!!
                Douggie
                • RCprince
                  • Jul 2007
                  • 1637
                  #53
                  FO' SHO' Douggie...If it's something Steve doesn't, sell I'll post it...Steve' to much of an honest guy plus his prices with service is beyond exceptional
                  • Steven Vaccaro
                    • 8721
                    #54
                    Thanks for standing by me guys.
                    I have them instock for $62.50.
                    Right now I have 4 of them. The wording has to be done for the ad. They are strong 125amp esc's. I got the unit to thermal again after trying to burnup the esc, which believe it or not is a good thing. I rather a thermal any day over a .
                    Before I sell it, I will be running some more tests tonight.
                    Funny note, I mount my test motors and electronics inside the workshop on 2 milk crates that have a piece of 3/4" plywood on top. Than move the setup outside for testing. Reason for this is theres something unnerving about a airplane prop spinning at 20k. I always worry about the sucker coming loose in a 15x15 work area. . With the neu motor and 150 amps and 14 volts, the prop creates so must thrust they are can be driven around the yard if not held down.
                    • SJFE
                      • 4735
                      #55
                      Ok so you have it in stock trim and it thermals @ 150amps. What about of you installed my monster cooler here. It's an mhz cooling block thermal epoxied to a thermaltake 12v fan seated on a copper plate with an extra 3/16th cooling line. The fan draws very little current. I'm curious to see how much further it can be pushed with some good cooling. I can send it up .
                      • Steven Vaccaro
                        • 8721
                        #56
                        "*Ok so you have it in stock trim and it thermals @ 150amps. What about of you installed my monster cooler here. It's an mhz cooling block thermal epoxied to a thermaltake 12v fan seated on a copper plate with an extra 3/16th cooling line. The fan draws very little current. I'm curious to see how much further it can be pushed with some good cooling. I can send it up . *
                        Image: http://i42.photobucket.com/albums/e343/STOAK/DSC02606.jpg
                        Image: http://i42.photobucket.com/albums/e343/STOAK/DSC02604.jpg
                        Image: http://i42.photobucket.com/albums/e343/STOAK/DSC02605.jpg
                        Image: http://i42.photobucket.com/albums/e3...K/DSC02603.jpg
                        I failed to mention that my esc was mounted about 8" behind the motor. The motor was spinning a 8" or so airplane prop that moved enough air to drive the test stand around the yard. And the 1515 was loving all those volts and amps.
                        One thing I did notice was the packs volts dropped under that load, more than I thought(dont remeber exactly). I will be testing with a newer set of 2s2p to see if the esc likes that better.
                        • calcagno45
                          • Mar 2008
                          • 1006
                          #57
                          WOW! Thanks for the thorough bashing eventhough I clearly stated:
                          I was simply answering the guys question on quckness if he wanted one that bad.
                          Trust me I support Steven more than I can afford. And when he is out of stock, I turn to the LHS to support the local business.
                          • SJFE
                            • 4735
                            #58
                            Your intent is understood. Most guy’s as a rule use a little more discretion when directing folks else where for out of stock items “IE” PM. Your case is not so bad. It’s not like you plastered a direct link in the open forum like some people do.
                            • calcagno45
                              • Mar 2008
                              • 1006
                              #59
                              Thats exactly why I stated it like I did. Thanks for understanding.
                              BTW, I got one of these from Txboatpilot with watercooling and proofing. And I dont know the data on Amps and all, but my ESC like this runs like a Champ in my 30" Cat hull(9xl, .130 flex, m445, 16 cells or 4s). She hauls butt for a good 5 minutes and is a steady 105-110 degrees after a run.
                              I had it thermal once, my fault tho.
                              • Steven Vaccaro
                                • 8721
                                #60
                                With that setup its should last a long time.
