Best cheap spray can paint ??
  • wade7575
    • Jul 2012
    • 108
    #31
    When it come's to clear coat's like the one part clear's like Rust-Oleum Automotive Enamel they are not as hard or shiny as one's like the 2 part in a Can SprayMax witch gives the best result's I have seen from anything out of a Spray Can.
    If you decide to try the SprayMax you must use a Mask with a Filter on it as the stuff will attack your lung's.
    Originally posted by SweetAccord
    Does anyone know if the Rust-Oleum Automotive Enamel as a clear coat would be ok to use over Krylon white?
    • MR2NR
      Jet Stream EP
      • Sep 2011
      • 159
      #32
      I always have better luck shaking the can good and then put the can of paint in very hot but not boiling water. (120F+) A couple minutes and reshake fast and have at it :).
      Kyosho K.I.T.T.
      • SweetAccord
        Speed Passion
        • Oct 2007
        • 1302
        #33
        Well I tested and used Rust-Oleum over Krylonn and it came out perfect.
          • 9488
          #34
          any pictures you want to share bro?
          • SweetAccord
            Speed Passion
            • Oct 2007
            • 1302
            #35
            Don't have any as yet. Will post when done.
              • 9488
              #36
              Right on buddy!
              • SweetAccord
                Speed Passion
                • Oct 2007
                • 1302
                #37
                IMG_0744.jpg Here it is. It has 2 layers of Krylon. Wanted a better finish so went over it with Rust-Oleum enamel and it's nice and smooth. Will let it sit and relax for a week before final sanding and adding the clear coat.
                  • 9488
                  #38
                  nice!
                  and I have that same boat..
                  • SweetAccord
                    Speed Passion
                    • Oct 2007
                    • 1302
                    #39
                    nice!
                    Sweet!
                    • HYDROJERRY
                      • Jan 2010
                      • 2503
                      #40
                      I use all rustolium spray can paints when i use spray paint and ive used the rustolium automotive clear coat on almost all my boats even the ones that i didnt use rustolium paint on and must say i love that stuff it sprays well and if you clear the hull over your decals and everything let it dry do a light wet sand it gets better but i must say that after one good thick coat for me i think its good unless you screw up then wetsand and spray it again,,, i spray everything outside in the heat and bugs and get great results..
                        • 9488
                        #41
                        Wow, this is making me more confident with this spray!
                        • SweetAccord
                          Speed Passion
                          • Oct 2007
                          • 1302
                          #42
                          Those look awesome! I'm using the Rustolium, waaaaay better than Krylon. Krylon comes out all rough and you MUST sand it. The Rustolium comes out much much smoother and you almost don't have to sand much to get it nice and even so you save time and money! Thank you all for your experience and advise.
                          • HYDROJERRY
                            • Jan 2010
                            • 2503
                            #43
                            Thanks SweetAccord, i like the rustolium enough that i do all my boats with it,, hell i still have my very first rc boat and wet sanded it and sprayed it with the rustolium clear enamel and it looks sweet again!!! PS i had a 1991 accord for years, sold it with 266,000 miles and got a 2003 used one and love it too so im a honda man also!!hahaha...
                            • SweetAccord
                              Speed Passion
                              • Oct 2007
                              • 1302
                              #44
                              So question hydroJerry,
                              What is the difference between the Rust-Oleum Automotive Enamel and the regular Rust-Oleum Crystal Clear Enamel? is this it?> 257884_AU_11oz_AutomotiveEnamel_Gloss_Clear_L.jpg
                              I was advised to use the Crystal Clear Enamel this> sr_crystalclearSP_L.jpg I presumed the Automotive would be better.
                              P.S. Mine is a 1990 with only 90,000 miles on it, all raced out lowered etc. and cherry. Everyone wants to buy it but I wont sell it. You just can't beat a Honda, they will run forever if you maintain them correctly.
                                • 9488
                                #45
                                strange they say it wears off?
                                uh does that mean you can drive your car with this clear
