I kind of agree Rumdog, but having a Genesis I don't feel the stock provided linkage is all that suspect. I don't think the control rod is flexing and part of my reason for wanting to run the boat without the rudder servo connected electrically is that there should be very little force against the linkage and servo at all doing this test. A point that I always taught was that rudder linkage always needed to be a pull direction for right hand turns and not a push. By that I meant that if we lived and died by right hand turns we never wanted the possiblility of a control rod bending or flexing under load. If the servo rotation and placement allowed for a pulling (it is called tension) force a piece of strong string would produce a right hand turn. So if at all possible I always setup my boats to rotate and pull the rudder to a right turn position. The stock inline placement for the Genesis did just that. I am concerned however about the nose heavy too wet possibility in this situation. My strut is set so that the very bottom of the strut housing just kisses the table and dead flat flush with the rear sonsons resting on the table too
Dave.
Dave.
