Greasing the drive cable....
  • jim1945
    • Apr 2012
    • 12
    How much grease do you need to put on the drive cable? Thick/glop it on.....or just enough to lubricate/coat the drive shaft
  • siberianhusky
    • Dec 2009
    • 2187
    Extra grease is extra drag, don't need a very thick film of lubricant to prevent metal to metal contact. I also find if I end up with to much grease it spins it out of the stuffing tube and makes a mess both inside and at the transom. Doesn't seem to do that on all my boats though.
    • Jeff Wohlt
      • Jan 2008
      • 2716
      I good layer then I like to dribble some oil on it. Makes for a nice slick mix.
      www.rcraceboat.com
      [email protected]
      • ashcossie
        • Apr 2012
        • 29
        any grease better than others iv been using vasaline
        • Rumdog
          • 6453
          Grimacer grease is great. I gOb it on. It breaks down quickly and the excess will exit anyhow.
          • Chilli
            • Jan 2008
            • 3070
            Mercury 2-4-c
            Mike Chirillo
            www.capitolrcmodelboats.com
            • Jeff Wohlt
              • Jan 2008
              • 2716
              Pretty good stuff here.
              www.rcraceboat.com
              [email protected]
              • martin
                • 2887
                Grimracer, i also use chainsaw bar oil as its thinner than any grease but very sticky.
                • JIM MARCUM
                  • Jun 2011
                  • 773
                  I usuall agree with Mark, but I'm in the grease to the max school, at least with a new stuffing tube and/or flex drive, I slather the flex shaft with Lithium grease (marine grease is good too). Put enough grease in the tube to push it out the motor end with the flex shaft. Rotate & move the shaft in & out to coat everything.
                  Tighten up the shaft & wipe off excess grease. It will fling off excess grease on the first run. Wipe off the grease splattered inside the hull with solvent. Future runs will only need a little cleanup.
                  On the other hand, if you remove & re-grease the flex drive at the end of the day (as you should), a thin coat of grease is OK. JIM
                  JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
