Extra grease is extra drag, don't need a very thick film of lubricant to prevent metal to metal contact. I also find if I end up with to much grease it spins it out of the stuffing tube and makes a mess both inside and at the transom. Doesn't seem to do that on all my boats though.
I usuall agree with Mark, but I'm in the grease to the max school, at least with a new stuffing tube and/or flex drive, I slather the flex shaft with Lithium grease (marine grease is good too). Put enough grease in the tube to push it out the motor end with the flex shaft. Rotate & move the shaft in & out to coat everything.
Tighten up the shaft & wipe off excess grease. It will fling off excess grease on the first run. Wipe off the grease splattered inside the hull with solvent. Future runs will only need a little cleanup.
On the other hand, if you remove & re-grease the flex drive at the end of the day (as you should), a thin coat of grease is OK. JIM
JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
