Delta Force 41 mono?????????
    • 7651
    Originally posted by millzee
    sorry man, didn't mean it that way
    I just meant the vid ending,no schrapnel,no nose of boat,just gone.A very expensive run.
    • keithbradley
      • 3663
      Here's a copy, but it handled great. I would expect the same from the DF 41:
      www.keithbradleyboats.com
      • Make-a-Wake
        FE Rules!
        • 5554
        How fast do you want to go? A Leopard 5692 1090kv would run great in that boat...that's what I would use if I were building it.
        He'd need to go 8s to get any decent speed
        • millzee
          Ozzie Bloke
          • Nov 2010
          • 1092
          :doh
          "Gimmy Toyz for FUN"
          • keithbradley
            • 3663
            Yes, I wouldn't run it on any less than 8s, more likely 9s.
            • millzee
              Ozzie Bloke
              • Nov 2010
              • 1092
              thanks, it looks good and will go on my list to build with a 1717 after the 35",
              better yet, do ya think shipping would be cheaper to Oz in one hit
              • millzee
                Ozzie Bloke
                • Nov 2010
                • 1092
                Ordered.
                • drwayne
                  • May 2008
                  • 2977
                  Sorry guy's but I've search a little and haven't found a lot of info on handling, top speeds or set up's on this hull, can anyone share there experiences or link some threads with this boat??
                  http://www.offshoreelectrics.com/pro...rod=df-delta41
                  I'm thinking of using the electronic's out of my ex df35:
                  Sport boat only
                  Neu 1527 1.5d 1500kv
                  Swordfish 240hv speedo
                  running 6s(33,300rpm) with a X447/3 or 7s(38,850rpm) X646/3, are these prop's close?
                  Should I go 1/4" flex with 3/16 step down or will 3/16 be enough?
                  Is this worth pursuing or should I keep looking, I want to get this order in tonight, please assist.
                  I said on the phone I had a DF35 Id send for postage to replace your graffiti covered DF35...
                  save the coin for the missus+squids next holiday..
                  W
                  • millzee
                    Ozzie Bloke
                    • Nov 2010
                    • 1092
                    sorry man, I forgot about that one but it's too late, all done. We hope to come to SA to go fishing as a Family very soon, here's to hoping.
                    • Chrisg81983
                      • Jul 2011
                      • 1556
                      First finish your twin sprintcat but on the df 41 I run a 1527 1y on 6 and 8 s and on 8s I am getting speeds in the very high 60's and on the last run my eagle tree said 71 but I think something was off with that but I am using nothing smaller than 450 3 blade as anything smaller can't even get the boat on plane it ran horrible with a 447 but the df 41 is a great hull one of my favorites
                      Good luck chris
                      • millzee
                        Ozzie Bloke
                        • Nov 2010
                        • 1092
                        thanks mate, advice taken and the cats the next thing going on the building table as soon as the sheds tidy and user freindly again, I've let it get pretty bad so tonight I'll finish cleaning and get into it again in a day or so, no paint, just drive shafts, trim, program and seal the hatch and I'll have the first video
                        • millzee
                          Ozzie Bloke
                          • Nov 2010
                          • 1092
                          #27
                          I just received the df41, Thanks steve!!!!!! My sheds full again, now I've got the cat to finish, then a df29, df35, df41, I love my mono's. After seeing this hull I have another idea in mind for a set up in this beast.
                          • Chrisg81983
                            • Jul 2011
                            • 1556
                            #28
                            Millzee I would recommend putting a strut on it not a stinger it makes dialing in much easier and watch placement of hardware as the transom is tight for space if you want to use trim tabs I will send you some pics of how laid it all out if u want let me know
                            Chris g
                            • millzee
                              Ozzie Bloke
                              • Nov 2010
                              • 1092
                              #29
                              I might try fitting two? Need to have a good look tonight when I have some more time, thanks.
                              • drwayne
                                • May 2008
                                • 2977
                                #30
                                Danny, mate .. finish what's on your plate before you grab for more.
