Large Cat for Racing Nitro
  • Steven Vaccaro
    • 8720
    #31
    Found a fuel thunderboat video
    Steven Vaccaro
      • 8012
      #32
      I've seen one race with a 35cc Mathe engine. It was quite heavy but did okay in rough water. I don't know if they all are heavy or if it was the gas build. You never lose sight of it on a racecourse though.......
      • SJFE
        • 4735
        #33
        Holy god that things sweet. Dude 60x20@10 pounds. What in gods name powers that?
        • Steven Vaccaro
          • 8720
          #34
          I read somewhere that it was 50" ?
          Steven Vaccaro
          • SJFE
            • 4735
            #35
            In the site under a teeny little link over on the right there is a specs board. The thunercat is 50 the thunderbolt is 60. The thundercat is quite ugly compaired to the bolt.
            • Ocean Racer
              • Sep 2007
              • 502
              #36
              Originally posted by Bill-SOCAL
              Also known as the "Zero Profit Principle"
              AKA Five Finger Discount
              Failure is the First step to SUCCESS
              • Ocean Racer
                • Sep 2007
                • 502
                #37
                It is nice looking boat but it seems kinda heavy. do u want to convert it or leav it gas?
                • NTM
                  • Jun 2007
                  • 59
                  #38
                  I looked into one ( a thunderbolt ) before picking up a drifter xl.
                  Supposedly it's quite heavy (12+ pounds) and the glass is a bit thin in spots. It's also not really built to handle speeds higher than 55-60 mph. Gel coat is quite rough too.
                  As for powering a 60" cat, i'm building mine with a pair of plettenberg 370/50/A1S motors, a pair of schulze 40/160 esc's and four flightpower 10s 4350mah packs wired in paralell. Propshop 5518 props at 30,000 rpm.
                  A 40" to 50" cat is way cheaper to build !
                  Regards,
                  Nathan
                  • Ub Hauled
                    • Aug 2007
                    • 3031
                    #39
                    they must have a different Thunderbolt molds at Expresscraft...
                    I have one, and let me tell you, it weights 8 pounds naked and the gel coat is pretty darn good... just to be fair, I'll take a look at it tomorrow in the sunlight to be sure that it is in deed smooth and to check for weak spots (that I believe are not there).
                    The one you saw (or mine) may have been from an older batch... BTW it measures 50".
                    • Ub Hauled
                      • Aug 2007
                      • 3031
                      #40
                      I looked at the hull in the sunlight today,
                      it looks like the layup is even throughout the build.
                      I am not sure they do wet on wet to join the top and bottom...
                      it seems they worked the joint a bit, but it was a good job,
                      it is solid and smooth all the way around... some minor sanding
                      done, nothing major at all.
                      It measures 50x16x7 --> give or take a fraction or two.
