Hi, I have a HOTR twin with leopard 4074's in it with swordfish 120 esc's on 4s each. I get no response for my motors. the steering works just fine. Sine both motors dont work i thought maybe it could be the receiver, replaced that and still nothing from either motors. I'm pretty much lost now and would really appreciate any help if anyone can. Thank you very much , Andrew.
HOTR Twin ESC problems.
You've troubleshooted the receiver and the motors. It has to be the esc's. Swordfish esc's need to be recalibrated sometimes. Here is a link to the Swordfish 120esc manual - http://www.astecmodels.co.uk/pdfs/Swordfish%20120A%20ESC.pdfComment
Hi
esc's dont chirp/beep .. the motors do that when the coils are energized..
umm, plug the motors back in ?
or
grab a Rx batt pack ...
try the steering from Throttle Rx port...Rx fail ??
I ran twin SF120 in maritimo.. had both bec to Rx.. they are switchmode and dont fight.
No beeps from either suggests Rx fail or Y lead fail.
regs
DocWWayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
@ 36" H&M Maritmo twin1512/1800 6S1P 88mph @ 40" drag hydro#1 twin 5692 12S1P .....always for fun @Comment
You can troubleshoot the receiver. Plug the esc's into the steering channel. Turning the steering on the radio and it will provide throttle. If that works, then the esc's are fine and the esc channel on the receiver is bad. Have you hooked the esc's up to another boat? Would be odd for both working esc's to be bad if they have worked before.Comment
I put a brand new rx in it, to double check it i hooked up the rx to my slash 4x4 and everything worked perfectly so know the rx is good, I will check the Y harness, didnt really thing there would be a problem with that but i will see.... Hey guys thanks for all your help with this I really appreciate it!Comment
and yet you have steering .... Y/N ?
Do you use bec from either/both esc? .. or a battery pack ....1/2/B ?
