HOTR Twin ESC problems.
  • oscarel
    • Dec 2009
    • 2127
    What KV are the Leopards?
    • drwayne
      • May 2008
      • 2981
      Have you checked resistance between the 3 motor wires ? 1-2? 1-3? 2-3?
      If zero or shorted(>10ohm).. the motors have burnt.
      It's extremely odd that bec works on both sides and yet no motor beep.
      • siranger
        • Apr 2009
        • 58
        Oscarel - motors are 2200 kv.
        drwayne - I do not know how to check the ohm reading.
        • siranger
          • Apr 2009
          • 58
          Just plugged in my old BJ26 motor and nothing coming out of that motor...
          • siranger
            • Apr 2009
            • 58
            One more thing i just noticed. When you plug the esc's in they both get a little green LED light that flashes once on the back of the circuit board, one of the esc's has three red LED flashed though after the initial one green flash.
            • drwayne
              • May 2008
              • 2981
              Well, that says the motors are okay...
              green light is power on confirmation
              red light state no signal from Rx [ or no script data in controller]
              Lets ask questions from a different perspective...
              yes it did work before multiple times, the boat ran great with no problems then all of a sudden this.
              1. why did that run stop ?
              one of the esc hit low voltage, it crashed, wtf it stopped, or a normal return under it's own power ?
              2. have these been swimming ?
              the opto coupler can corrupt data feed from Rx = no action
              if wet then sun dried, from a murky water.. residual debris can affect pcb .. both may need a good clean ?
              .. have you checked the white wire from both esc ?
              if dirty/broken or green ends.. this may be that voila' moment ...
              else, yup.. they're probably rooted !
              W
