Great points. I'll do it. The rudder is sharp just had to file down some dings.
Genesis on 10S not fast enough
Also,
Not shore if it was done,Yet.
But sanding the bottom of the hull adds air bubbles and less drag to,
I used #400 wet sand paper, From the stern sand forward 8", Towards the bow.
It works some.Comment
Probably ran the voltage to low..thats the only time I have ever seen batteries puff.Grand River Marine Modellers
How many break-in cycles did you do with the packs before running them at full amp draw? ThunderPower recommends several cycles at 3C-5C prior to full power operation. What was the pack temperature when you taped up the hull? Cold packs and high amp draws equals damage.
Very true with the battery temperatures. I preheat my batteries EVERY time on run. Actually I have a timer that turns on the heater box at 5am in the morning and shuts off at 5:45 when I walk out the door. If it is really cold I then transfer to the car lighter and plug the heater box in on the way to the lake. Cold batteries, lipo's, ALWAYS run slower than warm Lipos. If its a cold time of year, try it, you will be pretty surprised!Last edited by Gary; 11-19-2012, 02:16 PM.PT-45, 109mph, finally gave up after last bad crash
H&M 1/8 Miss Bud 73 mph
Chris Craft 16 mphComment
? ONLY IF THEY WORK
