Genesis on 10S not fast enough
  • Mtwinste
    • Jul 2011
    • 135
    Well I spent a bunch of $ to run 80mph on 10S and only hit 62.5.
    Using a X442. 10S. Leopard 1200kv 4082. 240amp ESC.
    What gives?
  • Rumdog
    • 6453
    The 442. That's what gives.
    • Mtwinste
      • Jul 2011
      • 135
      I have a X445, M445, X642 on hand. Would any of those be better?
      • oscarel
        • Dec 2009
        • 2127
        Do you have a way of measuring the current you're pulling?
        • Mtwinste
          • Jul 2011
          • 135
          I don't.
          • oscarel
            • Dec 2009
            • 2127
            The only way to know then is to start moving up in size on the prop, run for a min and bring it in and check temps. I also just saw this.
            • Mtwinste
              • Jul 2011
              • 135
              X or M series?
              4 pitch or 6?
              • Skullcracken
                • May 2010
                • 617
                What gives?
                Yah man, starving with that X442, I used an X445 on 6s and hit your speeds. You need an X447 or X450 at least.
                • Make-a-Wake
                  FE Rules!
                  • 5557
                  I'd try the m445 first........
                  • jcald2000
                    • May 2008
                    • 774
                    Get an Eagletree before you burn the whole boat down!
                    • oscarel
                      • Dec 2009
                      • 2127
                      Exactly. The $80 you spend will help save that $300 esc.
                      • Rumdog
                        • 6453
                        You dont need an eagle tree. Prop up,, check temps. The x442 is nothing with that setup. All the props you listed are safe, however that is a LOT of rpms. Short runs. A couple passes, then check temps.
                        • martin
                          • 2887
                          As been said that prop is to small, The setup you have calcs to 62- 65mph.
                          • TheShaughnessy
                            • 1431
                            I got 77 with the calculator using 44000 for the rpm. Prop needs to be well balanced at that rpm
                            • martin
                              • 2887
                              If you mean the OSE calculater i dont use that, My calcs were 62-65mph. Actual speed acheived was 62.5mph.
