Changing prop pitch?
  • tiqueman
    • Jul 2009
    • 5669
    #46
    But dude, he even said dude, he wanted to learn more dude... dude...
    Didnt we all stop saying that about 8 or 10 years ago... I think I stopped when Beavis and Butthead went off the air.... DUDE
    • steve-b
      • Mar 2010
      • 245
      #47
      Originally posted by britscoot
      I found changing the prop pitch is easy!!!
      Its still twisted right?
      Because if its not it wont work at all ya know.
      • tiqueman
        • Jul 2009
        • 5669
        #48
        That looks fast. How many amps does it draw. I have a black esc w/ red writing on it. Will it be strong enough?
        • JMSCARD
          • Mar 2010
          • 3444
          #49
          you guys are killing me here
          • steve-b
            • Mar 2010
            • 245
            #50
            As long as you keep the fluids topped up.
            • britscoot
              • 656
              #51
              Anyone know where i can buy a can of elbow grease for my flex shaft?
              • britscoot
                • 656
                #52
                will this work?
                i was thinking paper mache and duct tape.
                discuss...
                • tiqueman
                  • Jul 2009
                  • 5669
                  #53
                  Lowes, isle 7, bottom left about half way down
                  Yup, I think we are all a little "twisted"
                  Keep your blinker fluid topped off too, thats good for a couple mph and a bit more pitch.
                  • steve-b
                    • Mar 2010
                    • 245
                    #54
                    Does this qualify as "member bashing"?
                    • britscoot
                      • 656
                      #55
                      thats what she said!
                      • bigwaveohs
                        • May 2009
                        • 535
                        #56
                        This is what it says on the specs i was sent with the prop
                        3.75" (T.E) cup
                        2.81 (C.O.B) pitch
                        45.67mm diameter
                        That's a Trailing Edge cup of 95.25mm (3.75") and a Center of Blade pitch of 71.4mm (2.81").
                        The H-5 is a 45mm x 68mm, so the prop is pitched up and has a lot of additional cup....BTW, that's a good hydro prop with lots of lift...
                        I let the dogs out...
                        • graill
                          Retired
                          • 389
                          #57
                          You guys are mean. Jamin ignore the numbers, they are just there to confuse folks like you and i, i am pretty sure they are just production number and runs before the prop flies apart.
                          Jamin, I will explain in detail how to chage pitch on a prop, its easy to do and all you need are a pair pliars and a set of vice grips and a bench vise preferably. If its a plastic of carbon prop its even easier, simply use a lighter or butane torch and pliars.
                          What you will need. Thin leather or thin cardboard to protect the prop blade while bending.
                          For plastic props as you look at it from the side you want the curved end more forward for more pitch and more back torward the angled back side to decrease the pitch, using a torch or lighter (you will need gloves) slowly heat the prop end you wish to bend, remember not to let the flame come in contact with the prop as it may catch fire, not an issue as you can easily reshape it if you mess up. Make sure to eyeball the prop and bend them both to roughly the same angle, let cool and your done, sand any carbon or pliar marks off.
                          For metal props. If it is made of aluminum as some are you want to bend without any heat, use some cardboard to protect the metal blade and eyball about where you want to bend, using a vise is preferable along with some strong vise grips. firmly set the prop and grab the blade end with the vise grip, aluminum alloy is like putty so its easy to bend, give a decent yank in the direction you want and then take a torch till the aluminum just starts to smoke and then let it cool. If it gets white powder on it from the heat thats fine, it simply means you have hit molecular viscosity for that particular piece.
                          For stainless steel and brass or beryl its the same procedure, but let these type props get to cherry red and then quench quickly, using icewater. you want them to cool as fast as possible. again sand any teeth marks away with 1600 or 1800grit finishing sandpaper that the visegrip jaws leave behind, sand completely smooth, may take a few hours. *****Warning wear a mask that protects you from metal vapors, as these can be toxic!!!
                          These procedures take time to master and after its all over and done you may just feel you learned something.
                          Safety message:
                          Best to do these procedures outdoors on a workbench or in a ventilated shop so vapors dont get to you....And remember, safety goggles and gloves, have a fire extinguisher handy, ice and water on hand. If your under age 18 have adult supervision. safety first.
                          • bigwaveohs
                            • May 2009
                            • 535
                            #58
                            Should be good to about +/- 20mm...LOL
                            • graill
                              Retired
                              • 389
                              #59
                              Heh
                              • JCAustralia
                                • Jul 2008
                                • 304
                                #60
                                Hi guys
                                One serious question to clear things in my mind
                                Does more pitch in a prop add more load on the motor (and vice versa)?
                                Thanks
                                JC
