MHZ Mystic C5000 M Setup
  • domp444
    • Jul 2009
    • 846
    Hey guys! I'm thinking of buying the Mystic C5000 M Hull (from MHZ in Germany, not the US). I'll get it with the rudder, twin drives, carbon kit, and geico decals.
    It is the 114cm version.
    I would like to know what setup would be appropriate for this boat. Since it's an "A" boat, I'd like to know the best and most reliable setup. I heard that Lehner motors and Schulze ESC's are the best, but which in particular should I get?
    SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
  • dropps
    • Apr 2010
    • 29
    how fast do you want to go???
    I run my Mystic with 1521 und castle creations. speed something about 140 km/h.
    for me that´s fast enough.
    best regards
    • DINO7
      • Jan 2009
      • 162
      wich 1521?how many cells?props?
      H&M Intruder S twin Leopard 36/74/3270 @ 3S-HIFEI 200A
      MHZ mystic 114-TP4050 5D-HIFEI 240A hv ESC- @ 2 x 5S
      BANDIT S"love boat" LEHNER POWERED.. RCFASTBOATS.GR MINI COOPER CAT
      • domp444
        • Jul 2009
        • 846
        That sounds fast enough to me, haha. I'm not looking to go any specific speed, but I don't want to go slow either.
        And as Dino said, can you give me more specifics please?
        • Alfa Spirit
          • 2131
          2x6S and 2 motors 1500/1600kV, Castle Creations 1520 is a good deal
          • arrowskartax9
            • 130
            I just purchased a MHZ Mystic M Carbon/Kevlar with twin 1717 Castle, 180 amp seaking esc and twin G3 hyperion 18.5v 5s lipos spinning counter rotating Octura x450/3 props.
            • domp444
              • Jul 2009
              • 846
              Thanks for those setups.
              Arrow, how are you liking the quality of the carbon/kevlar hull? I want to get it and then put the Miss Geico decals on it, without having to paint it. Post some pics!
              I was thinking of the Neu or Lehner motors. And Castle or Schulze ESC's. Thanks for those suggestions. So I can assume that I'll be running 6s each side.
              • dropps
                • Apr 2010
                • 29
                hey
                i have 1521 1,5d 8mm shaft with fan and waterjaket.
                ESC: castle creations hydra 240 with extra cap-boards ( very important)
                for 120 km/h I use 5s 5000 40C Zippy flightmay
                for more speed I take 6s 5800 30C zippy flightmax
                Prop: right now I use a pair octuras x447.
                try to make so pictures
                just give me some time
                best regards: jens
                  • 7990
                  You clearly want top-end components, good for you. I get tired of reading recommendations of $100 motors and $150 ESCs for everything....
                  6S or 8S per side would give you plenty of speed and run time with a relatively mild setup. For 6S a couple of Neu 1527/1Y motors and Castle 180HV Hydras should work well. The larger Schulze 32-170 should work with the above motor too.
                  The biggest problem with these large twin cats is finding appropriate props (left and right hand rotation). With the above setup you can use the plastic Graupner props to find out what you need without breaking the bank. Then you can look for a pair of metal props....or not. For example a pair of Graupner K57 props would give speeds around 100 kph with decent temps and run times. Smaller props, less speed and more run time. Jens' recommendation above is more agressive but shuold work too.
                  Tell us your goals and we can give more specific recommendations.
                  • domp444
                    • Jul 2009
                    • 846
                    Yeah I wanna make this boat top-notch, since it's a great quality boat. I don't wanna get annoyed and switch out the components later on.
                    I'd probably get the Turnigy 6s 45-90C 5000mah lipos. Are those good to use in this setup? I don't know if the Hyperions are really worth the extra cash. Of course, if they are I'll buy them, but if the Turnigy's will work great then why not.
                    I was just looking at the Hydra 240 HV, will the 180 HV work just as well?
                    I'm not sure about these motors. 1515, 1521, 1527. What's the difference with all these? Prices seem to be about the same. Which would be the BEST out of all of those motors? Why not one of the 2215's?
                    I guess I'll use those K props to find the best setup. The X447's seem to be what a lot of people are using.
                    I don't have any specific goals in mind, I just want an awesome boat. But, the faster the better
                    • domp444
                      • Jul 2009
                      • 846
                      Oh and some pics would be great, Jens!
                      • bowzr6
                        • Oct 2010
                        • 17
                        Or.....http://www.youtube.com/watch?v=j43FR...eature=related
                        • domp444
                          • Jul 2009
                          • 846
                          I think I've seen all the YouTube videos of the MHZ and HPR cats, haha. The one in the link appears to be the larger one though, or does it just seem to be?
                          • dropps
                            • Apr 2010
                            • 29
                            no, it does not appear bigger, it is bigger. That´s the mystic of my friend Jens Seidel.
                            1,85m MHZ Mystic. using 3060 LMT motors und jeti spin 200 esc and 10s5p at the beginning.
                            to be honest, i wouldn´t use the 1527. They have so much torque, you will get some problems with the flex cables. One of my friends tried these motors in the mystic and had a lot of broken flex cables.
                            the 1521 are realy goog for that boot. 8s lipos would be too much weight.
                            take the 1521 an 6s if you take the 1,5d with 1900 u/volt or take the 1521 1,0d and use 4s and for the realy realy fast setup 5s lipos.
                            here are some pictures
                            mfg der jens
                            • dropps
                              • Apr 2010
                              • 29
                              more pictures
