MHZ Mystic C5000 M Setup
  • dropps
    • Apr 2010
    • 29
    even more pictures
    • johnf
      • Dec 2009
      • 1078
      Nice work. I LOVE that battery mounting idea!
      Catching Air!
      • domp444
        • Jul 2009
        • 846
        Originally posted by dropps
        no, it does not appear bigger, it is bigger. That´s the mystic of my friend Jens Seidel.
        1,85m MHZ Mystic. using 3060 LMT motors und jeti spin 200 esc and 10s5p at the beginning.
        to be honest, i wouldn´t use the 1527. They have so much torque, you will get some problems with the flex cables. One of my friends tried these motors in the mystic and had a lot of broken flex cables.
        the 1521 are realy goog for that boot. 8s lipos would be too much weight.
        take the 1521 an 6s if you take the 1,5d with 1900 u/volt or take the 1521 1,0d and use 4s and for the realy realy fast setup 5s lipos.
        here are some pictures
        mfg der jens
        First off, thank you for all of the pictures! You have a beautiful boat, very well done.
        Which motor will help me achieve higher speeds in the long run? It seems like the 1,5d on 6s would be faster, am I right?
        All of your suggestions have been really helpful, and I am currently thinking of doing the following setup...
        2x Neu 1521 1,5d
        2x Hydra 240 HV
        2x 6s 5000mah 45-90c LiPos
        Another thing - I would go with the 240 HV ESC if it's necessary, but if I can use the 180 HV instead then I'll do it. Of course, if I'll get better performance with the 240 HV I'll go for it.
        Thanks for all the help!
        SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
        • dropps
          • Apr 2010
          • 29
          thx
          I was searching quite a long time. I found nothing that would fit....for that reason i had to make my own mounting system.
          I can adjust the lipos 3 cm in both directions and fix it with one screw only.
          best regards: jens
          • dropps
            • Apr 2010
            • 29
            2x Neu 1521 1,5d
            2x Hydra 240 HV
            The 1521 1,5d on 6s will give you a revolution speed of nearly 41000 per minute.
            If you take the 1521 1,0d on 4s it will be 41000 per minute too.
            On 5s it will be nearly 52000 per minute.
            The difference between the 1521 1,5d on 6s and 1521 1,0d on 4s is nearly zero.
            There is just the difference in the weigth. Both motors will fit perfectly in the mhz mystic.
            But keep in mind: If you go down with the number of lipos you use, you will go up with electric current. While I was testing different props on my mystic I installed a logger: Peaks up to 250 A and continuous current was sometimes up to 120 A.
            My advice: If you have the possibility: take the castle 240.
            Best regards: jens
            • domp444
              • Jul 2009
              • 846
              Oh alright I see. So the boat would be faster on the 1521 1,0d on 5s? Since it'd be spinning 52000 rpm? Would that setup be hot?
              I also forgot to mention I would like to have run times of at least 5 minutes. I don't want to just go fast for 2 minutes and have to cool the motors/escs.
              I'll definitely take the Hydra 240HV now that you mentioned that.
              You've been really helpful and I think I'm going to go with your exact setup. It seems to be really good for me.
              • Alfa Spirit
                • 2131
                52000 RPM ?? 35000 to 40000 RPM is a maximum
                • domp444
                  • Jul 2009
                  • 846
                  #23
                  That's what I was thinking, Alfa.
                  • dropps
                    • Apr 2010
                    • 29
                    #24
                    why????
                    where is the problem going 52000 rpm???
                    • domp444
                      • Jul 2009
                      • 846
                      #25
                      Haven't posted about this in a while.
                      I spoke with a friend, and he recommended the 1521 1y instead of the 1d.
                      So my new setup will be...
                      2x 1521 1y
                      2x Hydra 240HV
                      Anyone else have any comments about the setup?
                      I placed my order with MHZ yesterday, and I hope to hear back from Shirley soon.
                      • dropps
                        • Apr 2010
                        • 29
                        #26
                        hey
                        with the 1521 1y you will reach something aout 34000 rpm idle speed ( i hope you understand what I try to say....)
                        This means that you will have something about 30-31000rpm load speed.
                        Well, that´s fine for going 100-120 km/h, depending on the props.
                        I always prefer more rpm.
                        I would take the 1521 1,5d on 6S
                        Props: x447
                        Speed 137 km/h (85 mp/h)
                        Current 120A
                        That´s what my eagle tree told me.....
                        best regards: jens
                        • DISAR
                          • Aug 2007
                          • 1072
                          #27
                          Very good information and nice battery mounting idea - very nice.
                          A friend of mine has same boat, 130 kph = 80 mph with
                          1521 1.5d (1900kv)
                          6s
                          turnigy 180
                          445 props
                          same as dropps suggestion
                          http://www.rcfastboats.com/
                          • domp444
                            • Jul 2009
                            • 846
                            #28
                            hey
                            Props: x447
                            Current 120A
                            best regards: jens
                            I heard that the d series of motors make ESCs go
                            Haha, that's why I was going to use the y motor. I would hate to blow a 450 dollar ESC because of a motor.
                            I understand what your saying about the RPMs. The d motor would definitely increase my speed.
                            You mentioned before that your current sometimes bursted to 250a, right? I was thinking of doing the Hydra 180 HV, but I see that the 240 HV is necessary. Thanks for the help
                            • domp444
                              • Jul 2009
                              • 846
                              #29
                              1521 1.5d (1900kv)
                              6s
                              turnigy 180
                              445 props
                              Everyone's recommending these d motors, haha. He's getting away with a Turnigy 180?
                              • DINO7
                                • Jan 2009
                                • 162
                                #30
                                Alexandros boat...from rcfastboats.gr
                                H&M Intruder S twin Leopard 36/74/3270 @ 3S-HIFEI 200A
                                MHZ mystic 114-TP4050 5D-HIFEI 240A hv ESC- @ 2 x 5S
                                BANDIT S"love boat" LEHNER POWERED.. RCFASTBOATS.GR MINI COOPER CAT
