Hey guys don't forget Steve is sell the 180s http://www.offshoreelectrics.com/pro...er-seaking-180.
6S ESCs
Yeah..............the Turnigy is the same as the Seaking.............i just recieved a Seaking 180a from him last week. Come to think of it, the Turnigy probably is the Seaking.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Yes the turnigy IS the seaking, remember hobbycity makes NOTHING of their own. Everything is rebranded!Comment
34" twin cat. Castle/Neu 1520's. x447 CR props. 6s1p per side. Seaking 180's. New cells. New motors. New esc's, with short power leads. second run, plug in tape up, hit throttle.....bang! starboard side esc up in smoke.
Ususally I do not run esc's to max specs. After asking around a bit, I decided to give it a go.
NEVER AGAIN!!
You'll regret it when it happens to you!Comment
I will state this only once as the Idiot Scotsman...DO NOT RUN ANY ESC AT MAXIMUM STATED SPECIFICATIONS.
DouggieComment
External rx pack. bec's disconnected. I've owned at least 8 of these esc. This is the only one, of ANY esc I've owned that I've ran at max voltage. Needless to say, it won't happen again!
No matter who says it's fine.
Unless you like expensive, stinky gooey messes.Comment
Any thoughts on 5s on my swordfish 120's? Turning twin 1518's with cr x447s on a 30" catComment
NO WAY
Edit
Those are huge props and you will have a stability problem also, and why twin motors...what cat?
Fluid, your thoughts?
DouggieLast edited by Flying Scotsman; 11-03-2010, 07:52 PM.Comment
I thought the issue was the amperage, not the voltage... I guess I won't be running my CC 1520 on my T180 after all...
As far as I understand the theory: more RPM = less prop.
With a CC 1518 @ 1800Kv I would use a "large" (42 to 47mm) prop on 4S (@ 26K RPM) and a smaller one (35 to 41mm) on 5S (@ 33K RPM).
Also the CC 1518 is rated @ 120A, I would use at minimum a 180A ESC or possibly even a 240A.
Amp ratings on motors mean relatively nothing. They can, and will pull way more amps. Especially in a boat. On a twin cat, running twins significantly reduces amp draw.
I used to run a 1518 in my Rico mono on 5s2p with a x548! Very reliable, and fast combo. Anything under 42mm probably wont even load that motor.Comment
