Himodel 200A ESC Price drop.
  • FE Wannabe
    • Jul 2007
    • 626
    #31
    Originally posted by FighterCat57
    This was just a sample. The production version will have one copper sheet per layer and multiple cooling pipes. I'll post up once I have some photos.
    Ooooh Copper, me likey! Good to hear! I was wondering when someone would start manufacturing the ESCs with Copper cooling plates.
    Now hopefully all the FETs will be in contact with the cooling plates.
    SoCal Fast Electrics|H&M Drifter S-CC1512/4S/T180A|Aeromarine Scorpion 32"- UL-1/4S/HM200A|Insane 34- CC1515 1Y/4S2P/T180A|BK Bandit S-CC1515 1Y/4S2P/T180A|Insane FE30 UL-1/4S/ETTI 150
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3480
      #32
      Well, I couldn't talk them into sanding, leveling and greasing, but at least they are using copper. They are stuck on using heat pads too. Here's the big mac;
      Copper / Heat Pad
      FET circuit card
      Heat Pad / Copper / Heat Pad
      FET circuit card
      FET / Controller circuit card
      The first models will not have tubing attached from the factory. The distance between the two copper plates is enough to insert a ~5/32 copper tube and either solder or thermal epoxy in place.
      It's a compromise, but they are not equipped to make changes to their products and are severely under staffed until February. We're very fortunate to have the opportunity to ask for these changes.
      I'm hoping to finish testing and get them to make a resin cast water cooled, waterproof version early next year. Preliminary results are good, but I need to get some eagle tree data to support.
      • FE Wannabe
        • Jul 2007
        • 626
        #33
        Copper / Heat Pad
        FET circuit card
        FET circuit card
        Me thinks they are using the thermal heat pad because they can't control the accuracy of the the placement of the FETs on the boards. The flexability of the heat pad could better match the uneveness of the FETs. Those pick and place surface mount machines are expensive.
        This is definitely a better setup than any of the other Chinese multiboard ESCs.
        By the way, how were you able to get hooked up with the manufacturer?
        It is cool that they are listening to the customer for their design mods.
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3480
          #34
          Ancient Chinese Secret.
          ...that and a few grand.
          • FighterCat57
            "The" Fighter Cat
            • Apr 2010
            • 3480
            #35
            OK, I placed an order for 20 of them with copper cooling plates. I don't know the price on them yet, but most likely about $45 give or take depending on the price of copper there.
            I'll keep ya updated on the status as things progress.
            • Karfrik
              • Jun 2009
              • 1177
              #36
              Let us know!!! i can use another one...............Al
              • FighterCat57
                "The" Fighter Cat
                • Apr 2010
                • 3480
                #37
                The order has been placed for 20 of them. I will let you know as soon as I get confirmation of completion date.
                • FighterCat57
                  "The" Fighter Cat
                  • Apr 2010
                  • 3480
                  #38
                  Should be a week or two. I'm waiting for confirmation.
                  • FighterCat57
                    "The" Fighter Cat
                    • Apr 2010
                    • 3480
                    #39
                    Quoting myself for a second time. Heh.
                    OK, about 7 days till shipping, so about two weeks, I'll have 20 of them WITH COPPER PLATES.
                    They want me to order more since the copper plate isn't cheap, so I might pool up and offer pre-ordering... but not yet. I want to make sure they are ready and see photos first.
                    Now we can request these direct from Suppo, with proper cooling and factory waterproofed for marine applications.
                    • Jacked1
                      • Jun 2010
                      • 772
                      #40
                      Sweeeeetttt!!!!!!!!!
                      Fleet: 55" Quad inline T600 Cigarette boat, Twin Mean Machine, Twin T600 47" mystery mono, 4082 Surge Crusher, 1717 8s Genesis, 4074 Villain, "mini mono", 52" Bonzi, Prather Funcruiser, 2 DPI 3.5cc tunnels, 5' Styrofoam recover barge
                      • FE Wannabe
                        • Jul 2007
                        • 626
                        #41
                        FC,
                        What is the voltage rating on these Suppo ESCs, and are these BEC or non-BEC?
                        Thanks for working with Suppo on this design.
                        Brad
                        • FighterCat57
                          "The" Fighter Cat
                          • Apr 2010
                          • 3480
                          #42
                          FC,
                          Brad
                          2-7s no BEC
                          Don't thank me yet. They aren't done and we don't have a price yet.
                          • FighterCat57
                            "The" Fighter Cat
                            • Apr 2010
                            • 3480
                            #43
                            OK, we can order them now. 20 piece minimum factory order, so I need to get at least 10 orders so I can place the factory order.
                            Basically it's this; when I get enough orders, I'll place the factory order. 1-3 weeks it will be delivered and I'll ship each ESC out the following business day.
                            • Karfrik
                              • Jun 2009
                              • 1177
                              #44
                              Thought they had BEC like the last batch.I don`t race so i`m gonna have to pass on this one,....bummer...but thanks anyways....Albert
                              • FighterCat57
                                "The" Fighter Cat
                                • Apr 2010
                                • 3480
                                #45
                                Model w/BEC is an extra $4. Select the option "w/BEC".
