Himodel 200A ESC Price drop.
SoCal Fast Electrics|H&M Drifter S-CC1512/4S/T180A|Aeromarine Scorpion 32"- UL-1/4S/HM200A|Insane 34- CC1515 1Y/4S2P/T180A|BK Bandit S-CC1515 1Y/4S2P/T180A|Insane FE30 UL-1/4S/ETTI 150 -
Copper / Heat Pad
FET circuit card
Heat Pad / Copper / Heat Pad
FET circuit card
FET / Controller circuit card
The first models will not have tubing attached from the factory. The distance between the two copper plates is enough to insert a ~5/32 copper tube and either solder or thermal epoxy in place.
It's a compromise, but they are not equipped to make changes to their products and are severely under staffed until February. We're very fortunate to have the opportunity to ask for these changes.
I'm hoping to finish testing and get them to make a resin cast water cooled, waterproof version early next year. Preliminary results are good, but I need to get some eagle tree data to support.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Well, I couldn't talk them into sanding, leveling and greasing, but at least they are using copper. They are stuck on using heat pads too. Here's the big mac;
Copper / Heat Pad
FET circuit card
FET circuit card
This is definitely a better setup than any of the other Chinese multiboard ESCs.
By the way, how were you able to get hooked up with the manufacturer?
It is cool that they are listening to the customer for their design mods.SoCal Fast Electrics|H&M Drifter S-CC1512/4S/T180A|Aeromarine Scorpion 32"- UL-1/4S/HM200A|Insane 34- CC1515 1Y/4S2P/T180A|BK Bandit S-CC1515 1Y/4S2P/T180A|Insane FE30 UL-1/4S/ETTI 150Comment
Me thinks they are using the thermal heat pad because they can't control the accuracy of the the placement of the FETs on the boards. The flexability of the heat pad could better match the uneveness of the FETs. Those pick and place surface mount machines are expensive.
...that and a few grand.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
OK, I placed an order for 20 of them with copper cooling plates. I don't know the price on them yet, but most likely about $45 give or take depending on the price of copper there.
I'll keep ya updated on the status as things progress.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Quoting myself for a second time. Heh.
OK, about 7 days till shipping, so about two weeks, I'll have 20 of them WITH COPPER PLATES.
They want me to order more since the copper plate isn't cheap, so I might pool up and offer pre-ordering... but not yet. I want to make sure they are ready and see photos first.
Now we can request these direct from Suppo, with proper cooling and factory waterproofed for marine applications.
Sweeeeetttt!!!!!!!!!Fleet: 55" Quad inline T600 Cigarette boat, Twin Mean Machine, Twin T600 47" mystery mono, 4082 Surge Crusher, 1717 8s Genesis, 4074 Villain, "mini mono", 52" Bonzi, Prather Funcruiser, 2 DPI 3.5cc tunnels, 5' Styrofoam recover bargeComment
FC,
What is the voltage rating on these Suppo ESCs, and are these BEC or non-BEC?
Thanks for working with Suppo on this design.
BradSoCal Fast Electrics|H&M Drifter S-CC1512/4S/T180A|Aeromarine Scorpion 32"- UL-1/4S/HM200A|Insane 34- CC1515 1Y/4S2P/T180A|BK Bandit S-CC1515 1Y/4S2P/T180A|Insane FE30 UL-1/4S/ETTI 150Comment
OK, we can order them now. 20 piece minimum factory order, so I need to get at least 10 orders so I can place the factory order.
Basically it's this; when I get enough orders, I'll place the factory order. 1-3 weeks it will be delivered and I'll ship each ESC out the following business day.Attached FilesFighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
