Throttle Fluctuation
  • Diesel6401
    Memento Vivere
    • 4204
    I don't think his batteries have enough cont amps for that motor. Unless he's running parallel on those. I'd imagine it's a lvc issue. If he is running parallel on those it is just at 88 amps using the 80% rule and if he hit a amp spike he's screwed. I think if he upgraded to batts with more mah his issue would go away.
    - Diesel's Youtube
    - Diesel's Fleet
    • Flying Scotsman
      Fast Electric Adict!
      • Jun 2007
      • 5190
      If he is running in series with that motor
      Douggie
      • gartman
        • 31
        I'm running parallel 4400 at 25c. What if receiver or antenna wires are to close to the motor, would there be some interference and cause throttle fluctuation?
        • scoota
          FE DOWN UNDER
          • Dec 2008
          • 409
          Are you running the batteries in series or parallel....did you flip the hull and components get wet?
          Douggie
          3511kv x 22.2volts = 77,944 rpm , he couldnt be could he ???
          3511 x 11.1v = 38,971 would be more like it , i hope !!!
          UL1- 1515 castle/neu / 240 swordfish
          SV27- with UL1 running gear
          33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
          • Flying Scotsman
            • Jun 2007
            • 5190
            What radio and Rx ....have compenents got wet...when did the problems first appear and 3S is SAW times on that motor
            Douggie
            • gartman
              • 31
              I'm using a Futaba T2PH with a R152JE receiver. The boat is used.
              • gartman
                • 31
                Douggie
                When i got the boat i had to add a Radio, Receiver and a Battery's
                • gartman
                  • 31
                  #23
                  I just read to keep all wires away 1/2 " from receiver , when i looked the wires were almost touching. I will never stop learning.
                  • chuff
                    • 25
                    #24
                    Paul
                    A pair of 4400 25c packs in parallel should easily be able to deliver over 200 amps if called upon. if you set-up is poor and things are binding, you could be overloading the ESC. Another possibility - if this is a used boat and the ESC was in it, you need to check the Low Voltage Cutout (LVC) setting. It might be set to 12 volts or so, in which case you will often be hitting the cut-out. The LVC is a safety feature to prevent over-discharge of your batteries but it needs to be set to suit how many cells you are running.
                    Chris
                    Try a different ESC if you can't find how to check the setting.
                    Chris
