Hi, I'm running 25" with a 88 max amp motor, 120 esc and two 3s 2200 mah 25c lipo batts. When i run the throttle the speed will fluctuate, sometimes turn on and off. gartman.paul@gmail.com
If you really want some help here you need to give us all some more info on your boat.
Hull, Motor, ESC Battery, Prop? when you post these general questions its hard to help.
We all love to help newbies out so post some photos and include more info please
Check your CAPS on the ESC .... Have a look to see if the ends of the caps are rounded , cause they should be flat , this could cause your problem , just because your motor is rated 88 amps ,it could draw double that by over proping ....
UL1- 1515 castle/neu / 240 swordfish
SV27- with UL1 running gear
33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
Its a v hull with Fiego 3511 kv, Castel Creation 120 esc 35mm prop
