Miss Vegas Deuce
  • jcgc
    • 63
    Thanks everyone for the replies. I really appreciate it. I'm pretty much sold on the conversion, just have to start ordering parts.
    Do I need to cut out all the blocks of wood that are glassed into the hull?
    • RandyatBBY
      • Sep 2007
      • 3915
      I've only rescued it while upside down a few times & there was maybe one or two tablespoons of water inside. I double-tape the front of the cowl at the right-angle hull-cowl joint; the only questionable sealing area. BTW, great news at the Doctor's
      I am thinking about the Smokin Joes Hydro mold build and Hoe to build the cowl and hatch.
      Yes it is great that the cancer is gone. Ya know I was diagnosed the same time as Droby. He did holistic medicine, I went with the doctors at Kaiser.
      Randy
      BBY Racing
      • v-spec
        Banned
        • Jun 2009
        • 940
        The Deuce version of the Vegas hull has more AoA than the earlier version to provide more top speed with the smaller .19 nitro motor which replaced the .21 motor on the originals. For a budget build the 1500 KV BJ motor with something like an Oct X442 could be a nice combo. The AQ UL-1 motor might be a little to weak for the 30" hull & the BJ really pumps out the torque needed - A Turnigy 180 would be a good reasonably priced speed control choice which would allow for more motor in the future. I've run the BJ motor [with a UL-1 SC] and Turnigy 4S 3600's in parallel in my 29" Titan rigged for LSO & ran 4 1/2 minute heats. Just a thought....
        Tony I drove one of the Vegas Deuce's last weekend. It's got a super tiger motor which is still an .18 sized motor just like the original .18 AQ motor. The original motor looked just like an OS .18 cvr but but was built like one of the old os .15 motors with a longer rod and shorter stroke. It was still a real OS though. (nitro I know you don't care lol)
        Anyways it was slow as a dog just like the original boat when it was stock maybe 27-30 mph I really doubt it was doing 30 though it really dragged the tail in the water too. The sponsons looked to be almost a 1/2 deeper than the original vegas.
        • v-spec
          Banned
          • Jun 2009
          • 940
          Yes cut them out. You can put the new mount right about there once you have all your stuff and know the cg is pretty close to being where you want it.
          • properchopper
            rcgoatbuild@snotmail.com
            • 6968
            FWIW, last Sunday I upped the M445 to a M545 on the Vegas, put the wing back on & Holy Moly !! Wish I had a vid-She was just flying - the now fairly old Turnigy's got a little puffy but WOW !!! I'll try for a vid tomorrow.
            • properchopper
              • 6968
              FWIW, last Sunday I upped the M445 to a M545 on the Vegas, put the wing back on & Holy Moly !! Wish I had a vid-She was just flying - the now fairly old 35C Turnigy's got a little puffy but WOW !!! I'll try for a vid tomorrow.
              • jcgc
                • 63
                I think I'm just going to get a Miss Elam hull and start with that. Converting the Miss Vegas is going to be alittle over my head.
                • properchopper
                  • 6968
                  #23
                  Done 100% correctly, It's a bit of work.
                  • Shooter
                    Team Mojo
                    • Jun 2009
                    • 2558
                    #24
                    Would love to see this vid Propper! I'm still running the X642.
                    • properchopper
                      • 6968
                      #25
                      Soon; I had to borrow the SC & rx for another boat.
                      • syncronized77
                        • Jun 2010
                        • 277
                        #26
                        After seeing the actual size of the Vegas hull...I'm now rethinking my power options.
                        Would a 2370KV 7XL motor from my E-revo be able to power a Vegas hull? It can handle a maximum of 4S.
                        Or would a 2150kv 540L 36x65 that can handle 6S be a better choice? Or I've got a BJ26 1500KV lying around that can be used?
                        Go Brushless or GO HOME
                        • properchopper
                          • 6968
                          #27
                          The 7XL is not a good choice- too "hot" Good motor for a smaller SAW rigger
                          The 2150 540L is also a little small and I doubt that a 6S pack would fit.
                          The BJ 1500's a good motor, prop it right [x442/x445] and you'd have a decent setup- not too fast but fun nonetheless.
                          Best bet : Leopard 2074 & Seaking/Turnigy 180- Rock & Roll !
                          • syncronized77
                            • Jun 2010
                            • 277
                            #28
                            OK...so I'll scrub the 7XL and look to the BJ 1500KV. Should I be running this on 6S?
                            But what about the 2150KV 540L on 4S? Still too small?
                            • properchopper
                              • 6968
                              #29
                              Again, you may have trouble fitting 6S packs. A BJ 1500 on 4S should work OK.
                              The 540L on 4S should be alright- hard to know 'till you try.
                              • Shooter
                                Team Mojo
                                • Jun 2009
                                • 2558
                                #30
                                [QUOTE=RandyatBBY;220304]I am thinking about the Smokin Joes Hydro mold build and Hoe to build the cowl and hatch. [QUOTE]
                                My vote would be to build it like the UL-1!! and Detox's Whip! Can't beat that hatch seal.
                                As for the Vegas, I've been struggling. I tried a full cowl (see first photo), but it just didn't look right, even if the front bottom nose was removed (the tape is hiding it). The cowl is WAY too far back!!
                                So........I just made a new plug (don't laugh Randy, my skills are limited!!). This one will put the cowl forward and have a separate nose cone, like the UL-1. 2pc designs are cumbersome to get ready, but the flat seal is bullet proof. IMO, that was the best thing about the UL-1 (and the drop tub design). I know PC loves those humps though!
