Turnigy vs. Hyperion Eagle Tree Comparison
  • 6S HYDRO
    • 1320
    #76
    funny i was just gonna ask you to talk to the guy and get me one
    • properchopper
      • 6968
      #77
      Just call Jeff; tell him your my friend; He'll throw in a free prop nut & I'll get points towards that toaster-oven I've been dreaming about
      • v-spec
        Banned
        • Jun 2009
        • 940
        #78
        What prop did you do 55 with? Is it the new H5 you ordered if so it's right about the speed I was running. If not what was it! (edit) Nevermind I actually decided to read the posts! Was it your super special M445 cause I was only getting 49mph with a s&b m445 and 57 with the H5. Either way those are some good numbers.
        • properchopper
          • 6968
          #79
          Yup, the new H-5. Bear in mind that I use the stock UL-1 speed control. If I could bump the timing up, maybe a little more speed, but the temps were so liveable that I'll leave well enough alone.
          • v-spec
            Banned
            • Jun 2009
            • 940
            #80
            So we have mostly the same prop and speeds just about the same too. Nice to know! What were your temps? My motor was 126 after 1.5 minutes on the endbell. I wanna be able to run for 2 minutes minimum but my temps soar if I even get close. It's fine at 1.5 minutes. Can't wait to meet up again and maybe actually run together with my new SV motor, will be a good comparo.
            • properchopper
              • 6968
              #81
              Didn't really check temps- I was too jazzed when I saw the GPS. Finger test showed nothing too hot. I think that with the lower timing of my UL-1 SC the temps would have been less than your Ice with higher timing. I'm hoping we can meet & play at Joe's when he gets back early Sept.
              • v-spec
                Banned
                • Jun 2009
                • 940
                #82
                I'm anxious to get to Joe's too! My last 126 temp was actually with timing at 10 like the stock esc I was using a cheap 150 amp though since I toasted the ice. Knowing my luck I'll have it running good then run into that magnet like wall at his Lake and sink it! I might order some of those nano techs now seems they are working pretty good for $75.00
                • detox
                  • Jun 2008
                  • 2318
                  #83
                  I ordered just one of these packs for my Raptor Rigger and Whiplash.
                  • detox
                    • Jun 2008
                    • 2318
                    #84
                    Using the UPS 3 day shipping option I ordered lipo Tuesday and received it today Thursday. Decals were included. My pack measures 155mm long x 48mm wide x 35mm thick...my lipo is larger.
                    • properchopper
                      • 6968
                      #85
                      I just re-measured mine; same as yours. I noticed that yours also had the 4.5 mm connectors & 10 AWG wire as well, not as specified by HK which showed 8 AWG & 5.5's. Not a big deal 'tho. You'll like these IMO !
                      • detox
                        • Jun 2008
                        • 2318
                        #86
                        8 gauge wire is TOO bulky. I like the 10 gauge better, but the cheap connectors are coming off and Castle 6mm bullets will be installed.
                        Why do they put those CHEAP connectors on there?
