Prop balancing HELP!!??
  • FloatDaBoat
    Bare Bones Fabricator
    • Sep 2009
    • 368
    #31
    Originally posted by SweetAccord
    Where did you get the shaft for your fabricated balancer or did you mill that yourself?
    I fabricated the shaft myself.
    I used 3/16” weld steel rod purchased from Lowe’s. I chucked the rod in a variable speed drill set at low RPM with a Velcro strap holding the trigger. I used a grinding stone in my Dremel Tool , at medium speed, to fashion the points (the rod & grinding stone were turning towards each other). Then I used 800 grit wet/dry sandpaper lubricated with light oil to polish them, with the drill set at maximum speed.
    A poor man’s lathe . . . .
    It requires a very steady hand to do a satisfactory job. Keep the rod as short as possible, as it will be closer to being in balance itself.
    I also made a 1/8” shaft from weld steel, but the rod was slightly oversize, & I had to reduce it’s diameter using 220 grit wet/dry sandpaper in order for it to pass through the smaller prop hubs.
    The 1” round ceramic magnets are also available from Lowe’s. I used six per side , & epoxied them together. I polished the magnet faces using 320 grit wet/dry sandpaper placed on a 1/16” brass plate, again lubed with light oil.
    Happy Balancing !!!
