Insane Boats P-Spec Sport Hydro 1st run with Vid !!!
  • Flying Scotsman
    Fast Electric Adict!
    • Jun 2007
    • 5190
    #76
    Originally posted by bigwaveohs
    Exactly!
    What do some other seasoned boaters think in this regard as I was thinking of setting up my Insane as I described, as I am a hydro newbie.
    Douggie
    • properchopper
      rcgoatbuild@snotmail.com
      • 6968
      #77
      Douggie
      Douggie, if Mark's boat handled just fine in the sixties with a single 4S, the P-Spec setup should have no problems with the same. This boat is STABLE !! I should know how mine does tomorrow when I return the 2S packs to Jan & run the spec setup on 4S.
      • Flying Scotsman
        • Jun 2007
        • 5190
        #78
        Tony and all, my question is what is better for a hydro not a tunnel hull setup 1 battery in the centre or 2 batteries positioned towards the sponsons?? again a newbie hydro question.
        Douggie
        • properchopper
          • 6968
          #79
          Douggie
          Douggie, Mark ran his INSANE HYDRO with one battery in the center with no issues. I will do the same. Either way, this boat is so stable that it shouldn't matter. Also, think about this : too much weight in the sponsons prevents some outside sponson lift in turns which could be beneficial.
          • teach
            • Jun 2008
            • 509
            #80
            I'm just a rookie but lowering your roll center is always a good thing in my humble opinion.
              #81
              You probably know that moving the battery has nothing to do with changing the roll center - that requires geometry changes. But keeping the CG lower may be helpful on some boats, however on others it either doesn't matter or it can be counter-productive. I discovered this on cat hulls - most I worked with didn't care where the cells went, a few handled markedly better when the cells were on top of the tunnel. Lap times told the story. We are not talking about large changes in the vertical CG here.
              Knowing what works for a particular hull requires experimentation, not some rule of thumb or "common sense". That requires a little work - which is part of the fun of the hobby.
              • Flying Scotsman
                • Jun 2007
                • 5190
                #82
                Thanks Jay, and I will experiment in different water conditions etc.
                Douggie
                • Shooter
                  Team Mojo
                  • Jun 2009
                  • 2558
                  #83
                  I've struggled with battery placement myself. One thing I can say is that batteries spread out result in sluggish roll response. This can be good, but can also be bad. When I tried spreading the batteries, it was more difficult to start the roll (lift the sponsons) in the first place, but it was also very difficult to recover (slow to respond) from a sponson lift. Think of a long stick with weights on each end that is rotating. It's more difficult to switch rotation direction the further the weights are out. Put them at the center, and there is not much difference with or without the weights. I think this is the reason that tight rope walkers use a very long stick (slow to respond).
                  Batteries in the center: fast sponson dance (quick roll response)
                  Batteries spread out: slow sponson dance (slow roll response)
                  Which one is better? I don't know. It seems to be a "balance act". ha ha.
                  • Darin Jordan
                    • 8335
                    #84
                    My $0.02 on batteries... I prefer to keep the weight as low, and as close to the centerline of the hull as possible. In MY OPINION, the further out from center you put the weight, the harder it is for the controll surfaces to control it. Control surfaces would include the planing portions of the hull itself.
                    Darin E. Jordan - Renton, WA
                    • Darin Jordan
                      • 8335
                      #85
                      ... By the way... Tony... I just got off the phone with Jeff... After appologizing several times for calling his boat bad names (these threads don't relay the light-heartedness I was trying to portray...) ... he agreed to sell me one! I'm in the queue for hull and hardware! Thanks for the contact info! Need to give Greg someone to race with up here.
                      • johnf
                        • Dec 2009
                        • 1078
                        #86
                        .I just got off the phone with Jeff... After appologizing several times for calling his boat bad names (these threads don't relay the light-heartedness I was trying to portray...) ... he agreed to sell me one! .
                        hah! Funny stuff. "so YOU'RE the guy that was bad mouthing my boats appearance!?"
                        Catching Air!
                        • Darin Jordan
                          • 8335
                          #87
                          I know... I was actually just joking around... I guess I forgot to mention that I LIKE UGLY... I use the term affectionately. Started using it when I designed and built my own FE Sport Hydro... It was "ugly" too... and I still have it and love it!
                          Sorry...
                          • johnf
                            • Dec 2009
                            • 1078
                            #88
                            haha, pretty cool. Well, at the speeds that insane hydro was running in the vids, I don't think anyone could tell what it looks like. LOL
                            Catching Air!
                            • Flying Scotsman
                              • Jun 2007
                              • 5190
                              #89
                              Darin, if you get yours before I do, I will be royaly pissed off, as that will show favouritism towards the home crowd . It is a very intersting looking hull that I will power with UL-1 components and a neu 1415 1Y and a Turnigy 180 amp marine ESC. prop is going to come from egneg (Chuck)
                              Douggie
                              • properchopper
                                • 6968
                                #90
                                Just got back from the lake; glad you got ahold of Jeff. Seems like many of the FE Royalty are placing orders ; can't wait to see what you guys do with the boat ; should be able to really unleash its potential .
                                For those of you who have been musing about battery placement theory/practice :
                                I just ran the Spec setup with a single 4S 5000 Turnigy 30C. Was so fast and smooth/steady [WFO in the turns] that it made a so-so driver like me look like a pro. 'Nuff said !!
