Insane Boats P-Spec Sport Hydro 1st run with Vid !!!
  • LuckyDuc
    Team Ducati Racing
    • Dec 2008
    • 989
    #61
    Fast isn't always pretty.
    • properchopper
      rcgoatbuild@snotmail.com
      • 6968
      #62
      You had me right to that point... It's FUGLY!!
      FAST-but-UGLY!!
      But I still think I want one...
      Take a good look : This is the view [minus the roostertail] likely to be seen by most racers
      • Darin Jordan
        • 8335
        #63
        I've seen that already, sitting on Greg's worktable... I even have my own video of it running on the course. My conclusion hasn't changed... Still UGLY...
        Function over fashion works well too...
        Darin E. Jordan - Renton, WA
        • Flying Scotsman
          Fast Electric Adict!
          • Jun 2007
          • 5190
          #64
          I love fast, well designed and built boats
          Douggie
            • 9488
            #65
            ok, I'm not sure where I read this, but how much is the hull and hardware?
            • LuckyDuc
              Team Ducati Racing
              • Dec 2008
              • 989
              #66
              White Hull/Cowl : $ 235 color top and/or bottom add $ 10
              Hardware - includes Turn fin and Bracket, Strut w. 3 teflon bushings, rudder with dual pickup/single outlet : $ 95
                • 9488
                #67
                Thank you!
                I'm thinking of this or a Whip20
                • properchopper
                  • 6968
                  #68
                  Originally posted by bigwaveohs
                  Have you had a chance to compare handling with the 4S versus 2x2S? I'm trying to decide on which battery config. to use...
                  Actually, Mark F runs his setup with a single 4S battery with great results. I'll be switching my setup to a single 4S as soon as I return the 2S batteries to Jan, who loaned them to me for testing. The reason I did the initial tests with 2S batteries was to show how easy it is to convert a UL-1 boat to the Insane boat - since most folks use 2S batteries in their UL-1's.
                  • ray schrauwen
                    • 9475
                    #69
                    How many Mah do you use with the Leopard motor? 4s1p or 2p?
                    Nortavlag Bulc
                    • properchopper
                      • 6968
                      #70
                      Mark runs a single 4S batt, IIRC it is 5000 mah. He can verify.
                      • MarkF
                        dinogylipos.com
                        • Mar 2008
                        • 979
                        #71
                        I'm using thunderpower 3850 1p 30c packs in all the videos. I would recomend using 5000 mah though if you got them.
                        Mark
                        • Flying Scotsman
                          • Jun 2007
                          • 5190
                          #72
                          An interesting point, but I think a hydro and a cat run better with 2 batteries in series, positioned close to either sponson as far as balance is concerned, just my 2 cents, but as usual my thoughts can be easily proven wrong
                          Douggie
                          • Greg Schweers
                            GREG SCHWEERS
                            • Oct 2007
                            • 92
                            #73
                            When I raced last Sunday, I ran ThunderPower 4S 5000/45C. This is the first time this boat has been raced. I don't brag about very many boats, but this boat ran and handled very good. I was running a 447 backcut, detunge, tips rounded, 6 laps on a course where the straights were only 250'. The motor temp was around 108, and I was putting 2200 back into the batteries. In the next few weeks I'm going to switch the boat over to a 3S setup for P-Sport; this boat should be running 75+ easily.
                              • 9488
                              #74
                              What motor are you running on 4s?
                              sounds awesome only using 2200mah
                              • Darin Jordan
                                • 8335
                                #75
                                It was a UL-1 Motor... P-Limited setup...
