Insane Boats P-Spec Sport Hydro 1st run with Vid !!!
  • ncornacchi
    • Jul 2009
    • 251
    #346
    Good luck with the build Kevin! Can't wait to see what you have in store for her....
    • knpc
      • 566
      #347
      Thanks Jeff
      Norm, I'll bring it by for a test run once I get her done
      Rico 29, Sprintcat 34, Insane FE 30 Hydro, 43'' Aeromarine Conquest
      • knpc
        • 566
        #348
        My hull was on the doorstep when I got home today . The fit and finish on it is great and the hatch fits perfect.
        Now its time to search a few threads for info and start building.
        • Flying Scotsman
          Fast Electric Adict!
          • Jun 2007
          • 5190
          #349
          Norm, how is my old UL-1 surviving.
          Douggie
          • Shooter
            Team Mojo
            • Jun 2009
            • 2558
            #350
            Originally posted by Fluid
            Now how much credibility would I have if I recommended something I had not even held in my hand......
            Build Pic
            Ha! I knew it! Credibility is sustained!
            How adjustable is that strut angle? Are the slots a tad wider than the thru bolts? If so, looks like the perfect set-up to me! hats off!
            • properchopper
              rcgoatbuild@snotmail.com
              • 6968
              #351
              props
              For anyone not of the mind or budget to go to a Sholund-style H-5 or H-6 : Since my H-5 got kaboodled while it was mounted on my Vegas with Brian driving it at the 2-Lap and found a turtle or something, I tested one of my highly sharpened and tip-cupped M445's today on my FE 30/Ul-1 motor spec setup and it was really fine. Great punch out of the hole, motor sounded highly wound out, and (with no GPS) the top speed looked just as good as the H-5 from where I stood. Watch temps - no increase in heat at all on the FE 30 today, although on my sponson-modded UL-1 things got warmer than I'd like at the last race in Feb. I'll do some more testing to verify this prop on the FE 30 but I really liked the way the spec-rigged boat ran with the M445.
              • v-spec
                Banned
                • Jun 2009
                • 940
                #352
                I've got an M545 coming in sometime to test as well as my modded H5 anxious to see how they work out. Waiting on lipo's...
                • simo71
                  • May 2010
                  • 74
                  #353
                  Has anyone used the Ul-1 hardware on the Fe30?
                  • properchopper
                    • 6968
                    #354
                    Should work just fine
                    • simo71
                      • May 2010
                      • 74
                      #355
                      Thanks propchop
                      • Rumdog
                        • 6453
                        #356
                        I've got one.. What was the reasoning for everyone going starboard side rudder on this hydro? I know some guys do it on hydros, but more commonly you see port side on hydros, and starboard side on riggers. It also looks like the FE30 hardware could be ran inverted (the bracket) to run port side rudder? No?
                        • v-spec
                          Banned
                          • Jun 2009
                          • 940
                          #357
                          You can swap the bracket around. Hey I thought you were getting the stealth sport hydro Rumdog?
                          • Rumdog
                            • 6453
                            #358
                            I am. Tracking says it'll be here tomorrow! Bout time! I really like the Insane too. Just wish I had someone to race with. Maybe I'll get the Insane too, and let one of my buddies pilot it. after a few lessons that is!
                            • v-spec
                              Banned
                              • Jun 2009
                              • 940
                              #359
                              Gotcha, did you buy the FE30 hardware then? That should be real nice. I like that hull too. I woulda bought one already if i didn't keep burning stuff up!
                                #360
                                Rudder position on hydros depends on the hull design. On some it does not matter - my DarkHorse ran the same with the rudder to the left or right of the strut. Some hydros need the force applied by the left-side rudder to keep the inside sponson down in the turns. But this makes the model very sensitive to flipping when trying to correct to the left.
                                Riggers generally don't need the insude sponson held down so the rudder works well on either side - but better on the right to reduce the flipping tendency. The Insane hydro acts the same way.
