540S vs 540L
  • Salty
    • Jul 2008
    • 30
    540S vs 540L
    Newbie question on the Feigao's.
    What would be the difference between the performance of the two sizes above with the same KV or RPM/V rating?
    Would the 540L just have a bit more torque than the 540S?
    IE. Let it push bigger props?
  • Make-a-Wake
    FE Rules!
    • 5557
    The "L" is a longer motor, it can pull more amps.....thus creating more wattage = more power. Here is a chart to look at.
    The 540 15s at 2590kv is rated at 43 "max" amps
    The 540 10L at 2602kv is rated at 61.............................
    • Salty
      • Jul 2008
      • 30
      So even though the KV rating is the same the 10L would be faster than the 15S with the same 11v battery and prop?
      • Salty
        • Jul 2008
        • 30
        or would it go the same top speed but not have to work as hard?
        • Make-a-Wake
          FE Rules!
          • 5557
          They would basically be the same speed with the same kv......... The idea is to get a lower kv larger motor and run it on more volts for more power and cooler temps.
          • Steven Vaccaro
            • 8723
            The larger L motor has more torque and more watts. So either it will push a bigger boat or spin larger props on a smaller boat.
            What is the project that you are looking for a motor for?
            • Salty
              • Jul 2008
              • 30
              This one...
              http://forums.offshoreelectrics.com/...ad.php?t=14698
              any tips for my lock nuts to secure the hatch Steve?
